Air pressure in rear suspension
Leeallen1111
Is anyone else having a problem with maintaining air pressure I the rear suspension of the F3T? I bring it up to 40psi and the next day and after riding for 2 hours it is down to 20psi
If it consistently drops to 20# you may ask your dealer to check it out on BUDS. Les (PW2013STL)from MN had a similar problem on his 2014 RT where it would not hold air above something like 13 #, turns out there is a setting for a high limit and his was incorrectly set at 13. So no matter what he set his at it would let air out until it was at 13#.
Check the Schrader valve core to see if it's loose..
Or spray a little silicon oil spray on it and the valve cap and see if that cures the leak?
