Air Horns on 2015 RT Limited
Jfhaas
I know this has been discussed but can't find it for my model. Where is horn and what horn do you all recommend. Appreciate your help. Thanks. Jack
LOUD
I have a strbel horn on my Valkryie and it is LOUD. Though not much seems to get the attention of a distracted and inatentative cager.
Hokning that loud horn can cause------
Kaos
Stebel Nautical
Will it fit in the same spot as a standard horn and is it difficult to install? Thanks.
Depends...
on the bike you have.
On the 2014 RT it fits in the same location without any modification. On the 2013 and prior RT's it will fit in the same location with a little (a lot) modification.
I was going to say "You must be from Las Vegas!" :roflblack:
Seems I wasn't that far off - :)
AJ
Kaos
I had the Bad Boy horn installed at Spyderfest and it is LOUD.
:thumbup::thumbup::thumbup:
Don't get sucked into the more expensive stuff.... BAD BOY HORN works well!
The cool thing is it doesn't cost a fortune to get and if you want more, then go looking....
Bob
