1. fan manual switch
if you live in warm climate or where there is summer
, do get this mod:firstplace: average ryder should be able to do this. i went to las vegas strip to test it out and first pic is 100 degrees ambient temp with heavy stop and go traffic with fan switched on. temp stayed at 4 bar no matter how long i sat there. i turned off the switch and within 30 seconds, it went up to 5 bars.
2. air dam
i did not get the kinda result others have. it does seem like temp goes down to 4 bar from 5 quicker once i get moving but not by much. it went thru the similar cycle between 4,5 and 6 bars but 6 bars seems to be a lot less than before so that's something. on the way back home, i rode at different speed from 45-70 mph and ambient temp was at 96 degree once i got to highway speed, but i could never get to 3 bars as some has experienced. i think i am the one who tested this in hottest weather so far.
bottom line is for $25.50, there was an acceptable improvement.:thumbup:
i am going to palm springs this weekend and it's 100+ there so it will really get tested.
3. falken ze512 tires in 175 65R 14
:thumbup: spyder rydes better, turns better. it is so much easier to turn the wheel, at first it felt like they were slippery but once i got used to the new feel and started taking turns at decent speed, tires held the line really good. i can definitely take turns faster. spyder is much smoother too.
last pic is a barrier i made out of some weather stripping to may be block some of the heat from my right foot and that was a disaster. my foot was cooler but engine was running hot hot hot. even with fan manually on, it stayed at 6 bars. i pulled over and removed the weather strips and it went down to 4 bars in couple of minutes.
2. air dam
