aftermarket CENTRIFICAL clutch assembly for 2009 spyder gs?
Does anyone know where I can get this part in a aftermarket version?
Considering the age and low numbers of Spyders that would have the clutch go bad, I really doubt that anyone would bother to make an aftermarket version. You might not even be able to get a rebuilt one. Your best bet is probably a motorcycle salvage business. There should be plenty of low mileage ones. Do you know if the clutch from a later version will fit your 09? If not, you may have trouble finding an OEM one.
What part of the centrifugal assembly do you need? All 7 parts are available as a kit for 317.99 usd from cheapcycleparts.com. But the 7 parts that make up that assembly are available individually for various prices. Do need all new parts?
I do not recall anyone having posted needing to repair the centrifugal assembly before. Any idea what happened.
Plates and discs
I know you can get plates and discs but the other parts will be as stated above... used or other oem suppliers....:thumbup:
There was some talk about stronger clutch parts...
But this is from about nine years ago: when aerocharger was offering a turbo kit for the GS.
Docdoru modified his; but I haven't seen him on here in years.
(At least not since he bought his other reverse trike... :bowdown:)
If you can get in touch with Lamont: he might know what Doc used, and where he got it.
