After Fabrication details for a Prop rod for the seat. 2022 RT-L
SLICE
I searched, Trust me.
So awhile back one of the members posted a picture of a prop rod for his seat to keep it up during fueling.
If him or her could chime in and provide details on the fabrication it would be nice.
Yes I have the super duty McMaster Car gas strut and ''helper spring'' and the seat still shuts under the weight
of the giant butt buffer gel pad.
PS, I used a bungie cord and it snapped and nearly took my eye out :yikes:. Don't use a bungie cord.
Yes, I saw that and now can’t find it either, Stephan…... sorry……Its plus is that it was attached under the seat and simply dropped down. I thought of doing it, but decided that the old 5” long T-bar Allen wrench that I keep in my glove box is easily accessible and works just as well for me.:thumbup:
Pete
I think it was me :roflblack: .... I have pics and an explanation in one of my Albums ..... if not enough info ....ask me questions. ..... Mike :thumbup:
If you could dig up the pictures it would be nice. IIRC you used a brass rod and hinge.
If you click on his username to the left of the post above yours, then click on 'View Profile' in the drop-down list, that'll bring up his profile - run down the left column until you see his Albums listed, I think the Gas Strut Replacement Album is probably the top one in the list. :thumbup:
I'm NOT talented in these area's.... all of my pics were posted for me by another member who is no longer on this Forum .... do what Peter said it's real easy....sorry, ...... Mike :thumbup:
So let me get this right, even the NEWER models still have the tank under the seat issue ? but a nice pricey aftermarket seat has a fuel door?
If you are referring to the GAS tank ... it has never moved since introduced in 2010 ./.... There is only one after-market seat ( that I am aware of ) that has a GAS DOOR as an option ..... Adding one is fairly easy, and cost approx. $ 75.00 in parts .... another member just did an installation .... PM Him
No, Mike, it wasn’t you. It was for a ‘20+ RT. This was a brass (or similar) rod, with a right angle at one end which was fastened under the seat, and a small rubber boot. When you lifted the seat, it automatically dropped down.
Pete
Sort of, AbNormy. You don’t need a fuel door on the new RT. It has a hinged front seat. Twist the key to the left and the seat pops up, enabling easy access to your gas cap, while your passenger remains seated. The only issue is that adding any weight to your seat, like a woollen seat cover etc makes the seat too heavy for the hydraulic lift, and you need to look for alternatives:thumbup:
Pete
Your pictures provided enough info to get my creative juices flowing, now to dig through my ''junk'' to see if I have enough scrap to fabricate a prop rod.
Stephan.
I just ordered a gas shock for my sled trailer through Mcmasters, I am surprised that you could not go up a few psi on the gas levels to make it work. But the old prop rod will always work for you!!:2thumbs:
The gas shocks get fatter as you go up in pressure and you run into clearance issues.
Stephan.
Stephan.
Read what " Peteoz " p[osted above .... I didn't realize your seat is different from my 2014 .... I am not familiar with the newer seats ....sorry .... Mike :thumbup:
Stephan.
Are you sure about this ..... I have quite a few GAS shocks in different length's and PSI's ..... the difference might be 5mm at most..... JMHO .... Mike :thumbup:
I used BLUEKNIGHT!!'s method (I think) on my 2008 GS as the Utopia backrest was too heavy for the strut.
When I lift the seat now a length of 1/4" rod falls down, It has a rubber foot on it.
Great, I love it.
Great, I love it.
Yes I made them for both my early Spyders also .... I only talked about the 14 RT because not much interest in the early models ..... Mike :thumbup:
The bottom of the seat has a lip I can drill into. The frame has a plastic cover over it to about midway up the rise, that will give me ''brake''.
I will mount a rod to the lip and hold in place with a magnet, when I fill up I'll just let the rod drop down and I should be GTG.
Looking forward to seeing your DIY … still waiting for my repair to be done on mine.
