Spyder Monkey
So I attempted to follow Lamonster's video on wheel removal where you did not have to re-tension the belt but it did not work out like I hoped.
I broke the axle nut and the lower shock nut free on the ground then lifted the whole bike just in front of the swing arm pivot.
When I got it in the air with no load on the rear wheel, I still had significant load on the lower shock bolt. If I removed that bolt, I would have had a difficult time getting it back on without a shock compression tool.
So I went with plan B and went ahead and took off the rear belt to replace the wheel.
The video shows the disc and hub being removed so I did that and took the wheel and new tire to a local tire shop. They replaced the tire but could not mount the wheel on their balancer. So now I am going to be a test candidate for Dynabeads.
Anyway, after a brainfart where I put the disc back on backwards, Nancystoy stated in another thread that it is not necessary to remove the disc and hub to change the wheel.
So after reassembly, the belt seems a bit tight. I don't have the right tools to adjust it. So I am left with a few questions for the wisdom of the forum.
1. What did I do wrong on the shock? I saw some post about different styles of spring, is it possible that Lamonster's technique won't work on my 2008 GS?
2. Do you guys normally take the tire to a motorcycle shop for mount and balance or should a car shop be able to do it?
3. What's the best way to handle DIY tension adjustment? Buy the tensioner kit, buy the tool from the manual, or buy some other tool?
Thanks for the help, slowly struggling my way to competent mechanic.
David
David
