Adjustable Handelbars
Munds1
Has anyone installed these yet? How do you like them?
How does the adjustment work? Tools required?
Please advise, Thank You
I'm curious about these as well... :shocked:
They seem like a great off-season project; my guess is that they're going to cause more headaches than installing a new chrome handlebar cover... :yikes:
Info on Tri Axis Adjustable Handlebars
Just had these installed by the dealer.
BRP instructions indicated 2.5 hour install time.
Actual install time by certified tech 5.5 hours.
Adjustment is via an 8mm allen wrench (provided)
also requires a 3mm allen wrench if you have the GPS Mount.
They are easy to adjust and have a wide range of angle and height.
Have ridden about 1000 miles since install and can recommend
this addition if you have short arms and have to stretch for the
stock bars.
This is the farkle many of us were calling for in the days prior to the RT. I am happy with the sitting position on the RT so will not be buying that accessory for either of my RT's. I know it will be a good accessory for those who need some additional adjustment.
I'd have to think that the adjustments swing both ways...
But you might be limited in forward adjustments by the distance to the dash and or windshield. :shocked:
stock bars.
Haven't put too many miles on mine yet,but really like them so far.
Geo.
