Adding Ride On to your tires - Good, Bad, Opinions?
gkamer
Sadly passed away, December '23.
So what is the general consensus for adding Ride On to your Spyder tires? Would it be worthwhile, or a waste of money. How about potential tire damage?
Not a fan of putting goo in my tires. IF I was to use dynamic balancers, I would use ceramic beads or the Centrics(sp?) rings.
Ideally, use weights and dynamic or static balancing.
If getting a flat tire is a concern, carry a plug kit and 12v air compressor.
I like Ride-On. I know people say that tire people don't like it. But I don't know why. It doesn't affect anything during a change. Doesn't get on the tire tools, machine, whatever. It stays put on the tread area.
The only downside is the out of balance you'll experience after leaving your bike sit for 2 weeks or more. That lasts (in diminishing degrees) for about 5 miles, depending on temperature.
I recommend using the Car Tire version. Ride-On used to recommend this for the Spyder for good reason. We are running car tires. However, for some reason Ride-On now recommends the Motorcycle Version for the Spyder. This makes no sense to me. The motorcycle version is more geared towards fast puncture seal and less towards balance. The car version goes the opposite direction. Which is appropriate for our application. And the car version is less expensive.
I like using Ride On. I have used it for the last 12 years and I have not had to balance my wheels. When I had my Yamaha Raider, I replaced 3 sets of tires and add Ride On and never had to balance the wheels. I recently replaced my rear tire on my Spyder and since I did not have a way to balance the wheel, I added 3 bottles of Ride On in the rear tire. Then you ride the bike for about 5 miles so that solution spreads in the tire. I did balance the front tires as I have the equipment at my shop.
I used Ride-On in my Gold Wing trike tires. Really did like it.
First time I drove it after putting the Ride-On in the tires it scared the be-jabbers out of me - tires jostling like I had 3 flats.. but after a couple of miles it smoothed out and was an excellent ride. I knew to watch for that thereafter and just relax until the fluid was redistributed in the tire.
I could ride down the road without holding onto the handlebars until an anomoly in the road would make the trike deviate from straight on. It gave me the confidence to continue to ride, mostly alone, out in the middle of no-where, at least not fearing a flat... well... at least not a flat from a puncture in the center of the tire. The website tells you if its a sidewall puncture the product will not help.
Per the website I put the motorcycle version in the trike tires (which are auto tires) because they said the motorcycle version will heal the puncture faster than the car product. I called them to verify and discuss that statement and was told they felt it important for an "exposed" rider at speed (not inside a car cage) needed to have that fast delivery of relief as they were inheritantly more vulnerable to danger in the first moments of the episode.
Ride On worked for me, if nothing else, it can save you if you have a puncture out in the boonies. The old formula was a mess but the new is fine for a tire change.
How do you apply or use Ride On? I looked at the website, is it one bottle per tire, how and when do you add it to a tire?
Thanks,
Jim
Thanks,
Jim
You remove the valve stem and put it in with the tube that Ride-On supplies. Pretty easy to do.
I installed Ride-On motorcycle flavour yesterday in my RTL and went for a short ride today. Using their online calculator, I used 12oz in front and 16oz in the rear. I thought there may be some wobbling until it was spread around the inside of the tires but in the short ride I was able to get in, none at all. Tomorrow I'll be able to give it a good test.
YMMV
Just thinking out loud. Have had 20 bikes, ridden all over on all kinds of road surfaces, in all kinds of weather conditions and not once had a unbalanced wheel/tire from factory or when new tires put on as well as had a flat. Carry compressor and plug kit for peace of mind.
But none of them were Kendas, were they?
Were they running car tires as the Spyder does?
I concur...
