JJW SpyderRider
For those of you that installed hallo lighting, how did you mount the lights? The bottom of the RT does not have any flat surfaces other than the frame and I’d like to know how and where you were able to mount a strip light. I want to install two strips of RGB LED lights from the front to the back. I use a MC lift and don’t want anything on the frame or below the frame. The strip has about 10 wires from the controller and can’t be spliced easily. I have worked with single color LED lights and spliced as needed but I need this strip to remain as on full run down the RT.
Any thoughts or information would be appreciated.
Thanks!
Thanks!
