Adding a Midland 75-822
pitzerwm
Riding with GoldWingers that use a CB to communicate on rides, I decided to get one too. Since the Midland 75-822 with a SR10 was recommended so that is what I got. Thanks to Finless and Lyonsden I'm a go.
Mounting the unit/s seemed to be the trick, and the pictures that I saw still left some questions, so here are more pictures of how I did it. I used a piece of plastic 2.4mm/,09" thick, heated it with a heat gun and put a small curve on each side so the unit can't slide side to side. I also cut 2 slots at the top to allow the belt clip screws to get past. I put it on the right side because my cup holder is in the way on the left. I haven't had time to give it a try on a ride yet.
