Added Stock Cruise control to my base Spyder ST
MrSchaefer
Hey SL!
Got lucky and found a Spyder ST-S being parted out on Ebay a few months ago and snagged the right-hand grip and switch assembly. The grip was kinda useless - it was heated, which is nice, but they cut the wire removing it and while I could replace that, having one heated grip seems silly.
The switch assembly was the reason I bought it as the ST-S had cruise control. Spent a few hours this weekend and my base ST with no wire splicing, no custom work whatsoever, now has fully functional cruise control! :yes::thumbup::ohyea::2thumbs: I think the part can still be located for about $200 new, sorry I forgot to grab the part number off the inside of the housing before I installed it. I can take the outer casing off and get that if anybody needs it.
I put together a vid in the how-to section showing the replacement process - link below.
Cheers and ride safe!
https://www.spyderlovers.com/forums/showthread.php?132823-Video-Adding-Stock-Cruise-Control-to-a-base-Spyder-ST
