According to SNOPES, THESE REALLY WORK!!
JerryB
Hi folks,
1. AVOID CUTTING YOURSELF WHEN SLICING VEGETABLES BY GETTING SOMEONE ELSE TO HOLD THE VEGETABLES WHILE YOU CHOP.
2. TO AVOID ARGUMENTS WITH THE FEMALES ABOUT LIFTING THE TOILET SEAT, USE THE SINK.
3. FOR HIGH BLOOD PRESSURE SUFFERERS ~ SIMPLY CUT YOURSELF AND BLEED FOR A FEW MINUTES, THUS REDUCING THE PRESSURE ON YOUR VEINS. (REMEMBER TO USE A TIMER.)
4. A MOUSE TRAP PLACED ON TOP OF YOUR ALARM CLOCK WILL PREVENT YOU FROM ROLLING OVER AND GOING BACK TO SLEEP AFTER YOU HIT THE SNOOZE BUTTON.
5. IF YOU HAVE A BAD COUGH, TAKE A LARGE DOSE OF LAXATIVES. THEN YOU'LL BE AFRAID TO COUGH.
6. YOU NEED ONLY TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
7. IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM.
SOME ADDITIONAL ADVICE:
NEVER,UNDER ANY CIRCUMSTANCES, TAKE A LAXATIVE AND SLEEPING PILLS ON THE SAME NIGHT!
:yes:
Jerry Baumchen
If you men take a sleeping pill, also take a Viagra. That way you won't roll out of bed during the night.
Hi SPECTACUALR SPIDERMAN,
Re: so how much of that advice is from personal experience?
Only the one about using a sink. I was 19, at a party ( a lotta drunk folks at that party ), and the homeowner said that the restroom was the 1st door on the left. I went to the 1st door on the left & only saw a bathtub & sink. Hey, works for me.
Jerry Baumchen
Thanks Jerry!
I copied and pasted #1 to my culinary group. Getting lots of LOLs.:roflblack::roflblack::roflblack::roflblack:
Pam
