R FUN
I had this experience on my first oil change done by the dealer. Shortly after I was at another dealer in the US having a CB installed and was advised of an oil leak but they were not sure were it was coming from but seeing I just had an oil change figured it must be dripping from the lower pan from doing the oil change. Shortly there after the bolt let loose and sprayed oil out and caught fire. I contacted dealer 150 miles away and they said it has happened several times. They said they would put in a hilicoil but checking on spyder lovers it was advised the casting is too thin and would cut into the inner works and cause a worse leak. Mine was the transmission upper bolt. I drilled it clear through and taped it and then got a longer bolt and put a lock nut as added security. This was 5 years ago and working great. Not sure which bolt is stripped on yours.
P.S. I was able to get the fire out with no damage.
Roger
Roger
