3K Check Up
AntelopeSpyder
I just called my dealer to make an appointment for my 3K check/ oil change ( Elk Grove Motor Sports ). They quoted me $289.00:yikes:. That seems a little steep. Is this about normal?
Seems fair. But for $60 of parts including oil you can do it yourself?:dontknow:
I paid in the high 200's in Denver too. These toys are not cheap. I'll probably do most of my own maintenance from now on.
:agree: That has been my conclusion. After this service I will be doing my one service. If it wasn't for the fact I am having MPG problems:gaah:, and I purchased it used I would probably start now. But I need the piece of mind that everything is working OK.
I had mine done before going to Magog cost $122.00. He said he did it by the book. His rate is $80 an hr
I had the 600 service done by dealer at $170. Did the 3K service My self cost $110 for oil n supplies. Also just had the 6k service done by a different dealer for $140 checked dps steering issue and adjusted parkin brake/belt-sparkplugs Did not to the valve check-Dealer said 12k or after. 1300 miles later i think i might need new plugs. Hope this helps! I think alot depends on the labor rate and size of shop. around here rates are flate rate for some service or 80 to 95 per hr.
