I have a 2021 RT Limited and recently the radiator cooling fans would come on and not go off even when I turned off the engine. Not good. I was close to my dealer, so I dropped in, and they had a tech look at it. It was determined that a relay for the fans was stuck and would not shut off. $17 dollars later a new relay was ordered. When I got home, I pulled the relay and waited for a new one. I got the new relay and installed it, problem solved. I was wondering if this could be a continuing problem and was going to purchase an extra relay. I wanted to touch up some paint on the front (I hate piano black), so I took off the Kott Grills and discovered a huge amount of bugs and other crap in there. I cleaned out everything and cleaned the stock grills, but I am wondering if that caused the relay to malfunction.
My best advice is to make sure you keep those grills clean on a consistent basis. I rode to Alaska from Colorado this summer (8500 miles) and going through Wyoming, Montana and Colorado there were a ton of grasshoppers. I spent three days cleaning once I got back but neglected to look at the fans. I now plan to keep a closer eye on the radiator fans.
I hope this helps everyone.
