Ok here we go,
I removed the cable and billett connector, it looks like it is a La Monster set up and I have been in contact since Monday and am waiting for a replym they had to send my question to the shop I guess.
This is the setup I believe:
https://www.lamonstergarage.com/lamonster-usb-cable-holder-can-am-spyder-motorcycle/
Since my bike has the HeliBars the cable was apparently too short and what it looks like it actually overheated at some time and the PO had glued the cable into the connector and its not coming out. So I would need a new billet connector and longer cable.
My thoughts since I have zero use for
BRP gone and I can still use my cell for a backup music source I can just leave that in the trunk on charge cable.
I installed GO, made the BT connection then uninstalled GO but I still have use of that BT connection. So the cell can go in the trunk or even fits up front glove box as it fits NP.
Returned the OEM power /mp3 cables to the glove box. From there I have my MP3 connected through the 3.5mm Mp3 plug and can plug that in to charge or just leave the thing plugged in.
Now to use my Garmin Zumo I unplug the 3.5mm plug and power cable and plug that into my real bluetooth receiver (shame on GO)
https://www.amazon.com/dp/B07TSN82BR?psc=1&ref=ppx_yo2ov_dt_b_product_details
Pop the Garmin on the mount and Im ready to ride. Just a note the BT receiver can be left on the power cable or if you leave it off its go for up to 10 hours on a charge. I did a test yesterday and it was still going after 7 hours.
At some point I may replace the cable but again I never have use for the cell sitting there and it looks like that connection is not waterproof.
Last question is, is the La Monster setup waterproof? Perhaps the setup got wet and and caused a short which caused the overheated connection?
I still may opt for a extra power cable in the glove box but its pretty simple just to disconnect and reconnected the devices I want to use.
Thanks all for the suggestions, I was not aware of the new USB connector sizes and you saved my a few dollars from buying the wrong cable.
My brain hurts after all this :bowdown:
