2020 RTL handle bar clamp - what bolt length & thread?
Longtimer
Getting ready to install a GPS clamp mount on my 2020 RTL I know there some problems getting the bolts out was going to change them to stainless does anyone know how long they are from the bottom of the head to the end and what thread they are was going to have everything here before starting. Thanks
They are M10 and neither the RT nor F3 parts list give the length. A call or email to Lamonster Garage might get you the answer and perhaps replacement bolts.
Changed the clamp mount no problems marked the bars to get them back in the same spot then removed bolts came out pretty easy and they are sure proud of there yellow lock tight any way cleaned up thread and put blue lock tight on them put back to gather tighten to 20 ft. lb the bolt are m10 ---1.5. 1.75 long from under the head Allen head is a 7mm
