2020 RTL belt tensioner (do I still need to adjust belt tension)?
Escorial
Just asking for the heck of it, if you have the belt tensioner would you still need to check adjust belt tension?
Or would the adjustment be at longer intervals?
Tia
Number one, it's not a belt tensioner, it's a vibration DAMPENER! And yes you will have to adjust your belt tension still, with the dampener off the belt. :2thumbs: You'll find that the belts don't stretch very much so making constant belt adjustments is not needed. How'd I do Baja Ron? ;)
Figured as.much but figure I'd ask anyway. You did fine, move to the head of the class
AMEN! Preach it brother! :thumbup: A man after my own heart! You are exactly right. And why I continue to campaign for using the correct terminology. A rose by any other name only goes so far.
