mikecronis
So.. it's been a long time since I've owned my RS-S 2013 (and RT-S) which I sold in 2016 but...
I believe nothing has changed much from 2013 to 2019 except for the Rotax engine going to 1330 cc and the RS-S dropped in favor of the Ryker 660 model. I had switched to standard bikes again (Honda VFR 800 Interceptor and a 2020 Yamaha R3 ABS).
I may be in the market for the new RT Limited 2020 or newer and I've scoured the Inter-Googles on the new 2020 and onward model of the RT changes.
Best I can tell is that the new model:
Wondering if anyone owned the previous RT Limited and their opinions on seat comfort / position, if anything I noted is wrong above, and I've watched the vid on the Slavic overview: https://www.youtube.com/watch?v=TgOrLpaifVo
Wondering if the rear hatch opens on its own (similar to the C8 Corvette frunk) or if there's a recall on that?
Wondering if any of the CanAm accessories are worth it as the RT Limited seems to come with everything I'd want (ie. is the extra lighting worth getting for function vs style, or the all-leather seat option; is it actually heated too?)
I distinctly remember my 2013 models had that front-end wandering feel as it "searched the road" to which the trick was to "let it wander" and loosen the rider's grip and lower the PSI in the tires to 15 PSI.
The Spyders before were counter-intuitive to sportbike riding with the yolk of course, and you always felt like "high-siding" in a turn, requiring a different riding style and weight positioning. (I'm familiar with this oddness).
How's noise comparatively and wind buffeting between the pre and post 2020 models? Personally, I found the 2013 model to be quite isolating (in a good way) but added the wind restrict add-on plexiglass pieces (are those accessories worth it?)
I'm not opposed to buying "used" (ie. 2020) because some deals can be had with mods such as the better aftermarket Baja Ron sway bar.
What mods are truly mandatory?
Thanks guys.. considering coming back !!
- Doesn't have driver-over-heating issues (mostly due to the highway board arrangement)
- The new brake pedal takes some "getting used to"
- The new audio may be better quality (it's hard to get the specs for the speakers before and after)
- The new RT has Bluetooth and also a CanAm proprietary app (ie. not Carplay/Android Auto) which requires a direct USB plug-in and Bluetooth connection
- Handling is improved
- Stability may be improved
- Seating position may have been lowered?
- Top speed may have slightly increased
