Not sure exactly what happened in your instance Sno, but the Nanny will cut engine power if the rear wheel spins up some % past the turning speed of the front wheels, and she'll only cease that power restriction once all three wheels get back to turning at about the same speed again. It's a safety feature!
. However, she
WILL cut in somewhat harder if you also have anything more than just a few degrees of steering dialed in - the F3's Nannies will permit 'more degrees' than the RT's Nannies do, but in either case it's not a heap of steering; maybe only 10° or so on the RT's, 15° or so on the F3's, +/- maybe 3°-ish in both instances? :dontknow: . This is because if you've got too much steering dialed in
AND that rear wheel is spinning, the Nanny 'thinks' you might be hanging the tail a bit too much and risking a tail slide/spinout, so she shuts you down until you're back under control. And if you've
SUDDENLY applied steering with the rear wheel still spinning, she'll even brake the front wheel on the 'inside' of the 'evasive turn' she 'thinks' you're taking in order to avoid an accident!
I just may have been known to start out doing pretty much the same thing you described above on the odd occasion, only without the complete shut down, and I know from experience that the Nanny does certainly cut in suddenly like that at times (have you ever lifted one front wheel in a sharp, high speed turn?
) but in my experience, it's usually only a Nanny initiated power loss for a moment or two while I back off the throttle a touch until the wheel speeds match up again &/or I straighten out the steering input a touch; then as the power starts coming on again I can
gently feed more power in and take off pretty rapidly without any further issues.
hyea: . You don't even need gravel for this to happen, altho it does tend to occur more often when taking off on gravel because of the lower traction & the ease with which you can get the rear wheel to break away & spin up; but you
can experience the same thing on the pavement if you are aggressive enough on the throttle & don't have too much weight/load on the rear wheel! :shocked:
That said, I'd surmise that you probably cut the throttle fairly suddenly once the Nanny cut the power, then feeling the pressure of the rapidly approaching/oncoming traffic, you likely twisted the throttle back on
juuust a bit too hard/too much in order to try and power off & outta the way - normally a fully justified feeling/desire.... only the Nanny sees all that on & off the throttle again while the rear wheel is spun up as indicating that you are
really out of control & need her help, so she mainained or re-instated the power cut even after the wheel speeds matched up again. :banghead: . I've had much the same thing occur (only without the 'impending crunch' of rapidly approaching traffic!) and so have learnt that when the rear wheel spins up,
GENTLY ease off the throttle (& degrees of steering) until the rear wheel slows it's spin enough to hook up again so that the Nanny lets the power come back on; and only then
GENTLY & SMOOTHLY feed in more throttle!! You can actually keep the rear wheel
JUUUST spinning a touch faster than the front wheels for some distance like that, altho you also need to make sure you don't have too many degrees of steering dialed in too, or she gets pissed off pretty quick & shuts you down completely!! :shocked:
Smooth & Gentle throttle and steering applications are the trick here! :clap: . It really doesn't take
too much practice to learn her limits and how to 'ride the edge' of the Nanny's intervention; and by doing so, greatly reduce the real upset moments where she catches you by surprise and makes you think '
Oh Crap!' as the grille on that Peterbilt approaching at terminal velocity causes you to suddenly add 'jet propulsion' stains to your shorts! :yikes: Just sayin'...
