2018 RT Ltd engine surging & dies at idle - any ideas
floridarider
Does anyone know of a possible problem my 2018 RT Limited has, where the Limp Home Mode briefly illuminated and the engine surges in RPM while driving. At idle it will die.
My philosophy is, try the easy stuff first; check your air & fuel filters, and run a fresh tankful of 91 octane fuel through it.
Possibly bad gas ???? .... If it's contaminated with water, the best thing I've used is a product named .. " HEET " comes in a red bottle & I believe it combines with water to make it burn .... It doesn't matter what grade of gas you use, fresh un-contaminated works fine. ... Spyders don't REQUIRE anything above reg 87.....Good luck .... Mike :thumbup:
I had something like that happen, I gave it a charge of seafoam it went away, I believe I got a dose of water. And like Mike said, a shot of Heet works also!!
HEET is a great idea, I recommended 91 cuz we have 91 w/ethanol here. Ethanol is OK for water, but the methanol in HEET would be better.
