2015 RT Gauge
jthornton
Anyone swap out a gauge on a 2015 RT for something else and would be willing to send the mounting bracket to me I'd appreciate it a lot. BRP changed the gauges in 2015 darn it.
JT
Yep JT and in fact I recently helped someone with this issue and your USB port.
The new bracket will work but as you can see in these photo's it's out of alignment a little thus causing the plastic bracket to bend to get the screws aligned.
Maybe these photos will help?
Bob
Thanks for the photos Bob, would you say one extra tapped hole is needed or do I need two new holes? Can you measure center to center the studs?
Thanks
JT
Thanks
JT
Yes if you take your current plate and drill and tap another hole it will line up better. One of the pics shows the right screw and how far off it is from your existing hole when the left screw is in. I bet you could get close enough with the new hole in your plate looking at the picture.
Sorry I cannot measure for you as I have a 2011 and this was a online friend I was helping. I doubt I could get them to take it apart and measure but let me ask.
Bob
John
I can send you one if you still need it, all you have to do is send it back when you are through.
Cruzr Joe
John
Cruzr Joe
That would be great to have on in my hand to measure and verify the locations of the holes needed. Can you send a gauge too?
Of course I'll send them back.
JT
