So the dealers get to see the 2014's on September 14. What do you think will be announced (besides colors being shifted between models).
Let the speculation begin.......
why?
because most of my bikes had them and i feel better millage would be achieved with a sixth gear
Did I hear somebody say "Flux Capacitor"? :roflblack::roflblack:
why do you want a 6th gear?:dontknow: I hardly ever get out of 4th!nojokeit would be nice for a 6 th gear
If you ride a Spyder correctly you move into fifth gear around 65-70 mph when the Rotax is in the lower end of it's optimum power band. If you had a sixth gear you would be upshifting at 85-90 mph and that doesn't make a whole lot of sense.
I rarely use fifth gear unless we are running in a 70-75 speed limit zone and my fuel mileage runs around 31-33 mpg. If the Rotax is lugged down under 4,000 rpm you will find it uses more fuel than if you run it in the rpm range where it is most comfortable and performs best.
A Spyder is not like most bikes.
Sorry , but you are forgetting that if you add a 6th gear it would lower the gear ratio and the Spyders sweet spot would no longer be in the 5000 RPM range, it would be lower. With that said, it would in fact save fuel if a 6th gear was added because your motor would now spin at less RPM's in it's sweet spot. Class dismissed !!!! :thumbup:
Go Back to the 2012 and prior frame and FIX the heating problems they caused in the 2013,s because I want No part of a New Spyder until they make it RIGHT for the people who spent their hard earned $$$ on a 2013 and are having heat, melting, and fire related problems!!!!!!!!!!!!
When people ask me about the Spyder and where to try it I tell them ALL about the 2013 problems because they have a right to know??nojoke
