Won't shift down to reverse anymore.  Yes, I'm pushing the left hand button.
I saw something about the F7 fuse on 2012-prior models. I have a "Left" and "Right" fuse panel on my 2014. I checked both F7 fuses, both are good. None of the fuses say anything about Reverse. There is a Reverse Actuator RELAY on the left panel, but I hear it clicking when I push the Reverse button, so doesn't sound like it's an electrical problem.
Just won't shift down to Reverse for some reason. The shift pedal is rock hard when down in first, not budging the slightest bit to reverse. All other gears are fine. I'm pushing the Reverse button until I hear the relay click, I'm holding the clutch lever fully down, I'm holding the brake pedal down, I've tried it both with and without the p-brake on. Never had this much trouble before.
