2013 St-S Front fender lights
truckracer
Help - I need help finding replacement light for the left front fender. This light was intermittent for awhile, now its out and the fuse keeps blowing.
Check the connector and wiring under the upper A-arm first.
BRP part number 710002691 LH Position Light. RS-S, ST, RT It should be about $65
Curious. ....
If the fuse keeps blowing out there must something going on. You should check the wiring to make sure it is not grounding out. Maybe pinched, rubbed through etc. Usually if the bulb goes thats it the fuse does not blow...:dontknow:
