2013 Can AM RT Limited Air Horns
JimBway
Anyone know if Air Horns are available for a 2013. I have found some for 2014 and up and I don't know if these can be retro-fitted for an earlier year.
Yep TricLED has one in their Ultimate Safety Bundle or as a stand alone. I had them mount it and it too needs the relay and direct power connection.
Great Horn!!!!
i put this on my 2017 RTL. train horns.org for motorcycles
Got any pics showing where you put that horn setup MSa? :shocked:
Still, I doubt very much that a 2013 RT would actually have enough space underneath the tupperware to fit trumpets that size within reasonable proximity to the compressor, so even if you did get it under there, on a 2013 there'd be a noticeable delay between pressing the horn button & getting any sound outta the trumpets!! :gaah:
I can see where a WOLO air horn might fit, but I'm struggling a bit finding space to add a slightly larger electric horn unit under the tupperware on my 2013 RT - my initial thought was to fit it in tandem with the OE horn, but after confirming how little actual useable space is under there, I might just replace the OE horn entirely with the much louder Fiaam electronic unit... it's not inches bigger than the WOLO units, & it looks like it might just fit into the OE space once that's out. :dontknow: Watch this space...
Got any pics showing where you put that horn setup MSa? :shocked: Still, I doubt very much that a 2013 RT would actually have enough space underneath the tupperware to fit trumpets that size within reasonable proximity to the compressor, so even if you did get it under there, on a 2013 there'd be a noticeable delay between pressing the horn button & getting any sound outta the trumpets!! I can see where a WOLO air horn might fit, but I'm struggling a bit finding space to add a slightly larger electric horn unit under the tupperware on my 2013 RT - my initial thought was to fit it in tandem with the OE horn, but after confirming how little actual useable space is under there, I might just replace the OE horn entirely with the much louder Fiaam electronic unit... it's not inches bigger than the WOLO units, & it looks like it might just fit into the OE space once that's out. :dontknow: Watch this space...
Watchin'
Horn Location
I can tell you I am not present home I am in Okinawa Japan presently so No. Sorry, but I installed it where the horn is for the 2017 Can am Spyder RTL I manufactured a bracket and installed the horn's below the compressorTight fit but it works great. I won't be home for another week so when I get home I can take Usomepics for you.
Works Great !!!
I hooked these horns up they come with the relay and I wired up and Man it is instant. No Delay what so ever. I powered off the Battery to the relay and used the ground off the battery. scares them right out of there cage!!! :yikes:
Right by the left floor board where the horn is on the 2017 RTL
