2011 RT Sway Bar installed?
traderbobnc
Bought a 2011 RT a year ago. Been going through it bit by bit. You've likely seen my posts about oil changes and Frunks and such. I see a bunch of posts about Baha Ron Sway Bars... so pardon the question: How would I know if I have a Sway Bar or not? What does it look like? Not how does it feel and what does it do. Thanks, b.l.
You have a sway bar on your Spyder. The RonBar is an upgrade. If you look at the links that attach the sway bar to the chassis, if they are plastic you have the OEM bar. If they are metal, then you've got the upgrade. You may also see a sticker that says BajaRon on the bar.
The following video may be helpful. You can fast forward to about 5:00 minutes for some views of the links and bar.
https://youtu.be/VqlTutXsIpQ
