traderbobnc
So, I come to the well again, for help with this temperamental femme fatale.
I despise electrical problems... as much or more than mechanical problems.
I'm a computer guy not an electrician or mechanic.
2011 RT: I think these are fog lamps - not designed to be on all the time.
They don't light - not when the headlamp switch is on high or low... not when I hit any of the rocker switches on the console panel.
I will admit to removing the Frunk when I was digging into trying to get to the airbox and the coolant reservoir, but I promise I tried to reconnect all the wires before I put the Frunk back on the bike. Full disclosure, I'm not completely sure the fog lamps ever worked, because I never used them on purpose.
So I started to explore the possibility that there is a fuse problem.
I downloaded a repair manual - so I'd have one - but admittedly, it covers 2008-2012 CanAm Spyder GS RS and perhaps not the RT.
Looking through the repair manual I see these
But they don't really cover the fog lamps (if that is indeed what they are)
The closest match would be MF7 (headlights)... so no match there.
There is no problem with the headlights. They work fine.
So, on to the fuses in the Frunk:
According to the "book", F12 is for the Fog Light Relay.
OK. Where is F12? According to the label, F12 is on the bottom right hand side of the fuse box - but f12 is labeled EVAP Cap, Fuel Motor, Prestarting relay... Not fog lamps. In fact, none of the labels on the cover mention fog lamps at all.
So, before I pull and examine every flipping fuse, which one should I focus on for those lights? If in fact they are fog lamps.
Secondly, which switch or control, turns those lights off and on - are they supposed to be on with the low/high beams?
Thanks in advance for sharing your knowledge and experience. I promise if I had any, I'd share it with you all.
