While the 'gearbox' itself is essentially the same for an SM5 as it is for an SE5, there's a
LOT MORE involved in making an SM5 into a 'Semi-Automatic' SE5, or more correctly, making your SM5 into a manual gearbox only with electro-solenoid operated computer controlled gear shifting and a Centrifugal Clutch! :shocked: So while it's probably
possible to 'upgrade' to the BRP version (if you have enough time & money to throw at it) I
really don't think you'll be able to do it cheaply or easily at all, Jonte! :gaah:
You'd need to upgrade the computers & possibly add wiring sub-looms; add all the shift solenoids & associated electronics; change the clutch from the manually activated unit over to the Centrifugal Clutch, which might even mean sourcing & fitting a new transmission housing/block assy; get a new LH hand-grip with the flappy paddles; and probably do a bunch more besides.... :lecturef_smilie:
BUT, that said, there
are a/mkt electronic shift kits available for some manual m/bikes, and I'm pretty sure that there are a few Spyder Owners out there who've done that to their SM5's, but without one or more of them providing some detail, I'm not sure where you'd start looking; and besides, doing that still isn't quite the same or as effectively integrated!
 So realistically, if you can't source/fit one of those kits that'll work, you probably only have 2 other options remaining: -
1)  learn to live with and use the manual clutch & shifter, which really isn't all that hard for most to learn to do reasonably competently; or
2)  sell that particular SM5 Spyder and find/buy a Semi-Auto SE Spyder. :thumbup:
Sorry, but them's the breaks, and the choices facing you!
PS: you'll probably notice that I've moved your thread from the 'Welcome' section, where these sorts of questions rarely get answered, largely because only a few of us regularly go in there
 and I've edited your thread title to briefly ask your question, cos that's the best way to get viewers looking in to see what you're on about, and without viewers, you won't be all that likely to get
too many responses!
