Just got in from Colorado-Wyoming-Montana-South Dakota trip... we rode just over 2,000 miles.
Average gas mileage 31.47mpg. Highest was 40.4 and lowest was 23.9mpg. While the average was good... the lowest mpg's came at the worst possible time when gas stations were hard to find. There was one unexplained time when the gas needle dropped like a rock from full to below the 3/4 mark in just 41 miles... and they weren't climbing miles! And, yes, I fill the tank the same way every time and visually check the level... which is NOT topped off to the fill hole!
The good:
My 2012 RT hit 11,000 miles on odometer while on the trip and all went extremely well even though I was expecting trouble based on all the things I've been hearing on SpyderLovers (oil leaks, water pump leaks, etc.). I'd like to report something good.
BajaRon's anti-sway bar was a dream. It tamed even the Beartooth Pass and the Needles. Highway crosswinds and huge passing trucks were barely felt. Huge improvement over the stock bar.
My riding friends rode Harleys and the Spyder easily kept up... and I did not long for my Roadking once during the trip.
The not so good:
My Texas dealer install a new rear tire for the trip and apparently remounted the wheel incorrectly. It left me with a dragging rear brake which probably accounted some poor Mpg's and it made my rear rotor extremely hot. The Can-Am dealer in Billings MT fixed the problem while I waited! (That would never happen in Dallas area!). Further... the Billings dealer would not accept payment for the fix. HUGE shout out to them!!!
The bad and dangerous:
On a routine gas stop... with approximately 1.5 gallons left in my tank... I removed the gas cap without incident... no pressure release of any kind. No sounds. No pressure left in tank. As soon as the fresh gas started pumping into the tank, there was an explosive blowback of fumes AND liquid gasoline. Explosive... Sprayed all over me, my clothes and the Spyder. I stopped. Thinking it might have been the gas pump giving out of fuel... I tried again... slowly. Again, an explosive blowback of the liquid gasoline and fumes. (I remembered the posts on "boiling gas" and figured this is what it is!). The tank finally settled down and I got it filled. This did not happen again on the trip... but IT IS A VERY DANGEROUS EVENT and I cannot explain it as of now. Why just then? Riding was normal... bike was not hot... etc.
Anyone have any ideas about this gas thing?
All in all, except as described above, the Spyder performed well.
TexGEOas
Argyle, TX
2012 RTS SE5 Limited
The good:
The not so good:
TexGEOas
Argyle, TX
