18 F3L Shifting input
So I have noticed something. When I am speeding up from a stop, and I shift, if I have the throttle steady and not moving it shifts quietly and effortlessly.
If I am increasing speed with increased throttle, sometimes the bike will slightly kick as it shifts. it is rare. Probably 1 time out of 30 shifts, but I do notice it. But only when I am increasing throttle.
It never happens if the throttle is steady.
Has anyone else experienced this and call it normal?
I have Drag raced both the V-twin and the 1330 .... with an SE trans. .... all shifts are with Full throttle, never noticed any type of hiccup .... JMHO ..... Mike :thumbup:
Yes, normal.
The transmission uses straight cut gears, so…..I believe you’re feeling the Engine/ Transmission adjusting to accomplish shifts “smoothly “. Input shaft and output shafts turning at different RPM’s ……ECM and TCM make very quick adjustments to accomplish a shift.
I was startled too when first experienced…….
