Myoutdoors
It looks like the 14' RTS has a different belt tension and alignment spec than previous years? The manual doesn't specify the belt tension but only states that the belt may contact only one pulley flange at a time and that the combined gap from the flanges should be 3.25mm when looking at the front and rear sprocket.
I purchased a krikit but I need to find out the tension in pounds for the 2014. How has everyone been adjusting the belts on the sprockets...mine looks like it's touching the rear sprocket but I haven't had a chance to look at the front at the same time to see if there is a gap.
