Craniac
Needed to install a 12 Accessory (Cig lighter) for a heated vest. Took quite awhile but I finally found the factory wiring for the frunk. If you remove the left side panel by the engine and them the left side panel on the side of the frunk, you can access the wires. I did not want the power supply in the frunk. There is no need to remove the frunk.
This pic shows the factory supplied wires and rubber hood for the frunk mounted cig lighter (just to the left of the top of the spring). This is after I dug them out with a pair of needle nose plyers.
The left side of the pic shows a screwdriver. The tip of the driver is positioned where the wires are zip tied to the frame. It is about four inches back but can be reached.
For reference, the left of the pics is the front of the Spyder.
