I know that there are some that are going to find fault with my questions for various reasons. The questions are exactly what " should be done " or what actually " needs " to be done.I have read the BRP specs and know what they say " needs " done but I question some of it and I've had opinions from several different dealers on how they look at and interpret it. I've always been of the opinion that if it ain't broke then don't fix it before inspecting it . Do the y gaskets really need changed if there's no sign of leakage ? I know of "preventative " maintenance procedures and believe in them however if there's no leakage then why change them ? If they do start leaking it should be apparent and then have them changed ? Other than poor performance until repaired , what is going to be damaged assuming it's not driven forever until new ones are installed ? I know that some will say that in the long run it will save money because the tupperware is already off and will have to be taken off later and labor charges applied.
Also is it really necessary to totally change out all the fluids ( other than oil and filter )? If coolant is at the correct level and testing shows it's still within limits , why change it ? I do believe in changing and flushing clutch and brakefluids but does it really need done at 12000 miles ? I normally do the changes after two riding seasons unless I really put on a lot of miles . I've had a lot of different cycles and this has always been my standard and have had no problems.
Then there's the sparkplugs , this will probably bring the heat down on me . Is it the plugs or wires that need changed or both ? Is it a " must " change ?
I'll probably hear that the difference in money between doing everything or not doing it all is negligible and foolish to worry about because penny wise sometimes means being dollars foolish later. Am I really being foolish to not do it all down to the wire as per BRP specs .? From the different quotes I've got , there's a huge difference in money savings . And one dealer did say the valve adjustment is very critical at this interval and "acted" very surprised when I mentioned that BRP has changed the miles for this. That ( honest ) dealer won't be getting my business for this inspection or any others ? Just a case of the customer paying for something he won't be getting !
I know everyone has an opinion , some right , some wrong and some just guessing .I've got a wealth of information from this site and hope to continue learning .What I've learned here has really helped when talking to techs concerning problems and maybe even kept them a little honest.
Prices have ranged from $650 ( not including oil change ) + parts and materials to as low as $350 including parts and materials ( except oil change ) but only replacing things that after inspection show they should be replaced. Very large range in labor with the lowest only charging for actual labor and not what BRP suggests for labor .Another saying says if it appears too good to be true it usually isn't .
Opinions ?
Opinions ?
