12 volt outlet in the trunk
Martman4
I have a 2012 RT S. The accessories 12 volt in the trunk is always on. Is there a way to have it switch on and off with the ignition. I know that from 13 and up is was easy. Just move a fuse.
On the 2012, the answer is no, unless of course you wanted to re-wire it. There is no easy fuse swap or something similar to that.
The beneficial thing about having the accessory always hot is you can plug your battery tender into it.
