Results 1 to 24 of 24
Thread: New Luggage
    Jul 2020
    Florida
    Default New Luggage
    Right after I purchased the Ryker in July, I fabbed up a bracket and I added some throw over saddlebags. Even though they were a little on the smallish side, and I couldn't lock them, they really worked well and served their purpose. Earlier this month, I ran across a nice deal on this set of lockable hard side luggage on sale for $169 on Amazon, and they came with a bunch of different mounting brackets, some of which I was able to use. They also come with rear lighting that I still have to hook up.
    These side cases were larger and heavier, so needles to say, a new bracket was needed to mount them. After the bracket was grinded down and sanded, I painted it black, along with all the other hardware, nuts & bolts. I also removed the inserts on the outside of each case and painted them to match the liquid steel trim on the Rally. I managed to get them mounted high enough as to not cover up the rear wheel, and I dont have to bend over to access them. Here's a few pics.
    My homemade bracket which I painted black.
    2020 Can Am Ryker Rally Sport Touring Edition
    Bossier LoUiSiAna
    Still have the link? Looking to add something to my two wheeler
    Active Member AVBIZ's Avatar
    Oct 2019
    Roswell, GA
    Looks great!
    1973 Honda CL 350 Scrambler (given to Son)
    2018 Vespa Primavera (Wife’s ride)
    2008 Spyder GS
    2020 Piaggio MP3
    Jul 2020
    Florida
    Link: https://www.amazon.com/Saddle-Lights...omotive&sr=1-1
    Looks great!
    Thanks,
    Are those " Mutaza " brand ..... if so there were problems reported about the locking mechanism Failing ...... I drilled a hole on the inside of both bags, thru the mounting bracket. Then welded a nut to the bracket, so I can put a bolt to keep the bag from coming off..... A bit more of a Hassel to remove the bags .... but I won't EVER lose them ..... good luck .... Mike
    Jun 2011
    Alamogordo, NM
    WOW, that looks absolutely great, especially with those wheels of yours.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Jul 2020
    Florida
    They're not Mutaza brand. But for that price, I'm sure they are some other Chinese brand. I posted a link above. The locks are working fine, but if they go bad its not much to replace them. I have a set of Shad side cases on my Kawasaki that cost more than triple the price of these. Honestly, they're not triple the quality.
    Oct 2015
    Lynden, WA
    Very nice job on building the mounting frame.
    Thanks for the pictures and Amazon link.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jan 2009
    austria
    RykerRick ... great Job
    Member Jomarfl's Avatar
    Jul 2019
    Zephyrhills, Florida
    Great job Rick, looks really good!
    Jul 2020
    Brea, CA
    Rick, Your New Luggage is looking Awesome. Its lockable design is looking good.
    Durham,Maine
    Very nice and clean looking, have fun with them!!
    2012 RTL , Pearl
    Jan 2020
    Pa
    Look great!
    Jul 2020
    Florida
    Thanks all. The biggest problem was trying to figure out a way to mount them, while still allowing me to use the Linq accessory plate. Before I had decided to do saddlebags, I had invested in the Linq plate and two different Linq top cases which wasnt cheap. That bracket was the key.
    Dec 2020
    IL
    Thanks for the info. Purchased bags now I need to make a bracket.
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    you went from one great set up, to another great set up. Looks awesome! The new bracket also looks a lot more heavy duty than the previous version.
    Jul 2020
    Florida
    Quote Originally Posted by Greven View Post
    Thanks. I ended up adding additional support brackets on the previous version because when the bags were loaded up, whenever I was riding on rough surfaces I experienced some flexing with that bag support. Adding two horizontal brackets underneath helped to stiff it up a bit and then it was fine. But then I saw these larger side cases on Amazon at a great price, thought about it for a little bit and I decided to go for it. I first tried to mount the new side cases on the original saddlebag bracket, but once I had the heavy mounting brackets installed on the back side of each case, they were too heavy for that original saddlebag bracket, even with the additional supports added. A more heavier duty main bracket was needed. Here's a pic of those brackets on the backside of each case.
    Feb 2021
    Amherst Ohio
    I just ordered them from Amazon also
    Jul 2020
    Florida
    I recently noticed that these match the Slingmods side cases that they sell as a 3 piece set with top case for $800 + 100 shipping. These have the same latches, same light location, the same lid inserts & round logo thats on Slingmods, except their insert & logo is painted black. Must be manufactured by the same overseas company.
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    Good looking rig. Wonder if whoever designed those bags has a Ryker in their garage? :-}
    Got me wondering if these old KG bags would fit? I've had them on several bikes since buying them new 40 years ago, so I've gotten pretty good at fabbing brackets, and they tuck in nice and tight.
    May 2019
    Canada
    Do you happen to have the measurements by chance of the bracket you made
    Jul 2020
    Florida
    Quote Originally Posted by Xander18 View Post
    The specific dimensions of this bracket was made to fit on the LinQ Accessory base, if fitting on just the Max mount, the measurements would need to be adjusted. I just made sure that the bags (if I hung them lower) would clear the driveshaft housing on the left side, and that the bracket would clear the ears on each side of the plate. Bags are evenly spaced on both sides. The side plates that hang down 3-3/4" could be made to hang down further based on your particular bag size & needs.
    After paint & install.
    Nov 2019
    New England
    I would like to know the material type as well as the thickness of the materials you used as well. Thanks. I would be planning on this set up when I get myself a Ryker, hopefully by this summer.
