Results 1 to 7 of 7
    Sep 2021
    Washington
    Default Rear Upper A Arm LED Installation Ideas
    Has anyone installed LEDs on the upper rear A Arm to increase visibility for drivers behind the Ryker? The current lighting isn't adequate for visibility. I'm looking for a simple DIY solution (red line of LEDs) that continuously displays and doesn't involve turn signals. Solutions that I have seen so far require disassembling the fenders and removing the wheels and that's above my current skill level. Thanks!
    Quote Originally Posted by thayden10910 View Post
    IMHO, RED LED's will match the bike's " running lights " ...... Mike
    Aug 2019
    Stoughton, WI
    Not sure how the Ryker rear looks, I did add red LED strip lights to my rear lower fender on my F3S when it was on. I tapped those lights into the license plate lamp. When I took it off, I added the same type of lights to the lower edge of my upper fender. Every little bit helps
    2022 RT Sea To Sky
    Active Member KnurledNut's Avatar
    Jul 2021
    Favoretta, FL
    IMHO, staying with WHITE LED's will be less confusing to other motorist's ...... Mike
    I don't think rear-facing white LED's are legal, except as backup lights. I could be wrong though.
    2021 , generic
    Quote Originally Posted by KnurledNut View Post
    That could be correct ..... and RED might actually be better, the Spyder running lights are also RED .... I'm going to change my post ..... Mike
    Sep 2016
    Chillicothe, Oh.
    I have the LED strip that runs along the top of the front fenders. White to the front and red to the rear. I HATE them and they will soon come off. Why? Because at night on a dark road they shine in my eyes and make seeing difficult in certain situations. I ride with a full face Shoei helmet and the lights hit just the right spot to affect my vision. My point being consider carefully where you put lights that will shine to the rear.
    2015 RT , Black
    Active Member RickD's Avatar
    Apr 2021
    Due South of Houston TX
    I put these on and am very happy with them. You do not need to remove the wheels, and the install, although tedious, is not technically complicated. https://youtu.be/Lj9ErraMDPo
