Anyone with BUDS who can delete DESS?
Anyone in Phoenix Arizona have their own BUDS-Megatech license? I want to delete that DESS of my spyder.
Also looking for BUDS Info. Following.
Your signature line says you have a 2012. As far as I know the DESS cannot be deleted using BUDS on 2013 or older models. So this may be not what you are looking for.
In 2014 an engineer ( and in this case I use the term loosely ) changed the DESS module ..... that's exactly when the problem began, prior to then I hadn't heard much in the way of complaints about Failure ..... Canceling the DESS won't speed up the start delay .... at least it didn't change mine when I had my DESS canceled ...... Mike
i am in gaffney sc can disable buds.. 860 334 5799
JIM EVANS
2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
My 2014 Spyder RTL just started throwing the dreaded DESS code and the spare key is not working. I can start it now with one key but am limiting that until DESS is disabled.
I'm looking for someone in Central Virginia with B.U.D.S. that is willing to disable DESS. I would prefer not to work through a dealer. I live in Chesterfield. Any help would be appreciated.
I Very Seriously doubt Any dealer will do this for you .... Also, The regular BUDS can't do it .... However, if they have an advanced BUDS license it will work .... Good Luck .... Mike
HI EddieN,
Have you seen the D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!!!! thread on this website?
https://www.spyderlovers.com/forums/...!!!!!!!!!!!!!!
I started the thread on 8/13/2015, the thread has a lot of views & replies providing excellent information on the D.E.S.S. issue & its resolution
Deanna
Reason: Added/fixed link
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Originally Posted by Deanna777
HI EddieN,
Deanna
There is a lot info in that thread. OMG! ....and good info too. As BLUEKNIGHT911 stated, the dealerships have only the Dealer/Tech B.U.D.S. license, not the Megatech required to disable DESS. So, I've ordered the new DESS module and planning to install it myself. What a pita. In any event, I understand the frunk has to be removed to access the DESS module but I haven't found any pictures showing the mounted module. This is something I'd like to see before I start removing the frunk. Does anybody have a pic? Is the module inside or outside of the firewall?
I did consider buying B.U.D.S. and a 1-year Megatech license but at $617, the module at $154 is a better choice for my budget.
Reason: Fixed link
Get in touch with Blueknight911, he has pic's of the DESS module in his Album.
Adrien
EddieN,
I started the D.E.S.S KEY CODE AGAIN!!!!!!!!!!!!!!!!!!, Thanks!
Good Luck with the DESS module install.
Please post the DESS module # in the D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!!!!!!!! Thread so that other people know what model # it is.
Deanna
Reason: Added link
Gremlin Bell
Sway Bar with Links
Half Cover
Its just above the battery where the module is mounted.
