Results 1 to 14 of 14
    Aug 2018
    Thousand Islands
    Default Best Looking (cleanest) phone mount in my opinion
    Lamonster bar clamp with quad lock motorcycle mount and case. My next step is working on wireless charging. Quadlock doesnt make water resistant wireless chargers si my plan is to use their car wireless charger and make it at least splash resistant.
    Jan 2017
    Bavaria, Germany
    Hello donhy,
    this looks great. Which mount do you use (Quad Lock Mount Model)? How did you attach the mount? Thanks for the help.
    2016 F3-S Special Series , triple black
    Aug 2018
    Thousand Islands
    Quote Originally Posted by susfrat View Post
    Hello donhy,
    http://www.lamonstergarage.com/can-a...amp-lamonster/
    https://www.quadlockcase.ca/collecti...tor-motorcycle
    https://www.quadlockcase.ca/collecti...rcycle-scooter
    If you want to change security lever color:
    https://www.quadlockcase.ca/collecti...ut-front-mount
    Plus case for your phone
    Default Nice set up....
    It is a nice set up and thanks for adding the links so we can search it out... congrats
    Oct 2017
    Salem, OR
    Can you tell me what torque settings you use to tighten the bolts on the handlebar? I can find the order but not that. After riding yesterday I decided to adjust mine.
    btw - I agree. I have one too.
    Aug 2018
    Thousand Islands
    Quote Originally Posted by gnorthern View Post
    I use my weaker hand as torque specs
    Mar 2019
    Hagerstown MD
    torque is 28nm
    2019 F3-S , Monolith Satin Black
    Florida
    Quote Originally Posted by donhy View Post
    where did you buy that USB port for charging your phone?
    Aug 2018
    Thousand Islands
    Amazon, it's usb charger / voltage meter
    https://www.amazon.com/Charger-CHGee...of+usb+&sr=8-4
    Florida
    Did you have to drill to enlarge the hole? also it wire directly to the battery, and you capped the switched ?
    Aug 2018
    Thousand Islands
    Quote Originally Posted by Jwill View Post
    Yes and also wired a quick disconnect plug
    Florida
    Wow it looks really nicely done. I’m not the geek guy. By could you please directed me to where can I buy all that please? Thall those quick disconnect plug.
    Aug 2018
    Thousand Islands
    Amazon as well
    https://www.amazon.com/MUYI-Waterpro...ick+dis&sr=8-3
    Florida
    just so I understand it correctly. You take those 2 red and black wire from MUYI 5kit tie it with the 3.0 car charger right, then you connect the other end of MUYI 5 kit with one of open harness at the trunk are?
    by the way what kind or size of drill bit that you use to enlarge hole?
