Results 1 to 25 of 36
    Active Member cbredneck's Avatar
    May 2013
    leesburg fl, Kent Island Md
    Default Brake fluid change and BUDS
    Anyone done the DOT 4 brake fluid change. Was the BUDS program required?
    [SIGPIC][img]https://www.spyderlovers.com/forums/maps/map.prov.png?states=[img]https://www.spyderlovers.com/forums/maps/map.prov.png?states=BC.ABhttps://www.spyderlovers.com/forums/maps/map.prov.png?states
    Nov 2012
    North Las Vegas, NV
    Yes, just did it by pumping the brake. No BUDS needed. Turn on the key to release the park brake then shut off the key, beeping will stop after a little while. Then bleed as normal.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2013
    I am not sure that you have the same platform as the 1330 thanks
    Houston
    2013 and the newer RTs have the exact same brake system. Regardless, the above answer is correct. There really is no reason to cycle the abs unit with buds as part of a regular flush and bleed. Only if air is introduced into the system.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    PK,
    Is it too difficult to share here with us folks who don't do Facebook? Thanks
    Jay
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    At the moment, very difficult with only the phone.
    PK
    2008 GS.....PE # 2888
    Jun 2015
    North Bay, Ontario CANADA
    You should consider joining the FB group. Well managed and good info.
    I agree. I personally never had a Facebook account, but I finally decided to set one up so I could access this group. Well worth it. Strictly technical only topics here with lots of good information.
    May 2013
    which fluid did you use ? super or low viscosity
    Feb 2014
    Quote Originally Posted by cbredneck View Post
    Hi!
    Did a change on my 2008 GS SM last year.
    Used an vacuum ejectorpump connected to my old aircompressor, worked like a dream
    Did the clutch too, the fluid was really dark and dirty.
    Regards Anders
    Jun 2015
    Quote Originally Posted by gunnar View Post
    Hi!
    Regards Anders
    Would you have a photo of your set up?
    Default As I see it...
    The reason for the buds system is to clear the nanny control unit. You know the one that puts on the brakes and kills your fun.. seems doing it without leaves what's in there as the new fluid bypasses the system which only operates by computer/buds under those special conditions. Not to say you don't have the bulk of the fluid new and things will be refreshed and working like new. If you never met the nanny your fluid will be new in there...
    Jan 2013
    Northeast Ohio
    Where is the ABS module located and does it have a standard bleeder screw?
    Feb 2014
    Quote Originally Posted by spydermanstever View Post
    Connect the hoses and go
    Jun 2015
    Thanks for posting the pic "gunnar". Where can one buy this unit?
    Feb 2014
    As comment against the ejector type bleeder. Those units create more flow than vacuum. No doubt it can pull the fluid through the system to provide a good bleed.
    The downside is, and I have learned this a long while back is to degas the fluid prior to bleeding. The ejector is not best for this operation. The fluid should be placed in a sealed glass jar with a means to pull near 30" of vacuum on the fluid. This will remove the micro bubbles. Fluid with micro bubbles will always have a softer or mushy feel when compared to degassed fluid.
    Using the ejector to bleed degassed fluid into the system should be a great option.
    I personally just use the Mightvac bleeder for all of it. Degas and bleed.
    I have never used an ejector type bleeder but would suspect is could very easily drain the reservoirs dry if not careful.
    All the best, whatever method you choose.
    PK
    Yes it´s true that you have to be careful and refill the reservoir to prevent it from going dry, but it is not that difficult to do.
    The ejector in the pic, well i live in sweden so you might not be interested in going that far for it but you should find it or simillar in a wellsorted carshop.
    //Anders
    Feb 2012
    Spring City,Utah
    Two questions. I looked for the Spyder tech page on facebook but could not find it. Do you have a URL?
    Where can I buy the Pentosin brake fluid? Does NAPA or AutoZone carry it?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Oct 2014
    Central Texas
    Default Preparnig to flush brake fluid
    Just went through the service manual and was following up with notes from experienced riders. I don't see where any fluid is bypassed by not finishing with BUDS. The VCM is flushed manually. Looked at the line diagrams and again couldn't find a line by passed. BUDS appears to be a pressure and functioning check, not a flushing operation.
    Can you show me what's bypassed?
    Default B.U.D.S. & HORSE PUCKY
    I could be wrong .....but I believe according to your Manual ....BRP wants you to hook up to BUDS after anything is done on THEIR SPYDERS ( actually yours ).........I'm surprised they haven't extended this to include ....after you get some BRP air from a dealer ......and of course after you put Gas in it..............Seriously tho, A lot of stuff you do DOESN'T NEED a BUDS check.....If you do the service procedure correctly .......if it doesn't the Spyder will tell you.....It will run, but it will flash a warning !!!!!...........So try it without ...first..........Mike
    There are hydraulic lines running to the calibration module. (found in the electical components front) You can do the brakes and bleed the system without going there but if anything is pushed into this unit you can not operate it without the computer. Buds is used to do that. In the case that after doing brake work you find that you can still not bleed the system to work properly you need to have it checked by someone with the buds system...
    Sent from my SM-T560NU using Tapatalk
    Nowhere
    Reviving an old thread for a bit...
    dies anyone one know the book time for flushing the brake system? I was told that the spyder would be ready in 2 hours. Now they say it's a 6 hr operation. Yes, this is MMS so I expected to be lied to.
    fWIW, 2014 RT
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    No way it is six hours. Not sure what the book time says. I would guess about and hour. If you had a lift like most shops do, they can prob do it under an hour.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Harper, Texas
    Quote Originally Posted by Spyder 42 View Post
    fWIW, 2014 RT
    The flat rate manual calls for 3.4 hours. Since that is determined by doing the job on a pristine bike, most shops will increase that by a percentage.
    Phoenix
    2016 RTS--Was told today $637 to do a brake flush without changing the brake pads. $125 per hr. Tax not included. 5-6 hr job.
    Flushing it myself. Probably will not flush ABS module.
    Mar 2013
    Quote Originally Posted by marty1096 View Post
    Well it looks like someone is trying to get rich off of service. The one time I had my dealer flush the brake system on our 2014 RT it was under $100.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    ...………...Did that person have a mask on ….. was His name Jesse James …… because it's highway robbery …..jmho…. Mike
