Originally Posted by flyjake
OK, after I saw your report I went on Amazon last week and ordered a pair (LI-1157RCZ), "only 1 in stock." Put them in this morning, took a 50-mile trip through stop-n-go, and they worked beautifully. This so far is the only LED bulb available with built-in circuitry that will work with the Spyder. Any ordinary LED will trip the computer and set up the "limp mode" reading.
I have the Sport rack and it took a while to install; loosened the rack, removed both rear side panels and under panel, and removed one screw on each brake light assembly. I wiggled each assembly down enough to reach in, turn each bulb socket counter-clockwise and pull the socket out. Removed each bulb, replaced with led and put everything together again. (It helped that I have small hands; otherwise the whole rack would have had to come off.)
I am planning a long trip and did not want to worry about replacing a bulb on the road. When NMN "(ESI)" has the Givi bag lights available, I will order and install those as well, and that will give me lots of brake light !!
I'm going to give them a shot too as sending in my parts, etc. just won't work. I'm also wanting to buy the GIVI bag lights from NMN - as soon as they are listed on their website.
Fire,
Why doesn't sending your lights in work? It only took a few days...was a very simple process...the lights are bright as heck and, of course, work fine...
Send on a Monday, you'll have back by Wed. or Thursday, unless you live in an extreme location.
Two questions, one easy.
1. Do these Pilot LEDs flash initially when brakes are applied and then go into steady mode?
2. Any thoughts on why they are not DOT approved? Made in China and not submitted for DOT review? Do they lose some brightness if not viewed directly from behind like some LEDs? Components don't meet DOT stds? ???. Checking local Auto Zone, Advance Auto, etc, but looks like Pep Boys may be only oulet in Michigan.
Some companies don't want to spend the BIG $$$ to get the full DOT testing done on their products to sure they meet DOT requirements.
Without the testing being done they can't be sure the products are DOT compliant and are sure they meet the grade?
So, although anybody can say their product is DOT compliant, the fines are HUGE if you say they are, and testing shows in fact they are not DOT compliant after you said they were.
It may not seem like DOT testing should be important, that is right up to the point there is an accident! Then the Lawyers all seem to think IT IS I BIG DEAL for sure.
MM
Originally Posted by bone crusher
Fire,
Right now Spyder is my only form of transportation. Other vehicle was taken out by a deer. Maybe come winter time----- but I won't give up riding my Spyder for a few days very easily at all.
These pep-boys units are NOT DOT certified - says so right on the package - for off-road use only. My guess is they are cheap--- but then again what should we expect for $25 ???
I would much prefer a unit that can just plug in where the stock bulbs go, so for $25 I may give these a shot.
1. no flashing
2. i am guessing no money to get it dot certified for when it's retailed at 25 bucks led itself is working very well and these have wider dispersion than others i've seen and yes pepboys are the only ones that have them for now and they just got these in themselves.
6 states down 42 states to go
Bump...these LEDs still working ok?
no problem for 4000 miles
also got these from superbrightleds.com and they are much brighter and have wider dispersion and match hid light well but available in amber also.
Break light change, OMG!
I picked up 2 LED tail lights today from my local Lordco store. Part # is HIL-1157R. List cost is about $20.00/ea. Any Napa or auto parts store should be able to source these.
Cheers
Bruce
Cheers
Bruce
Amazon $10. [ame]http://www.amazon.com/Vision-HIL-1157R-Red-Replacement-Bulb/dp/B000ES867W[/ame]
Senile Member
100,000 hours ... that's like the life of the bike. Won't have to touch them bulbs "forever".
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
Originally Posted by Trickie Dick
These bulbs do not have load equalizers...they will cause your Spyder to go into limp mode. The Pilot LEDs have them and they work great. I have had them for 10,000 miles now with no problems. Amazon and Pep Boys carry them.
Good to know. Is this the one?[ame]http://www.amazon.com/Pilot-LI-1157-Brake-Tail-Lamp/dp/B000NWPTU6[/ame]
That is not it. The one we are using will come in package of two and have black plastic frame on top.
Try this link:
[ame]http://www.amazon.com/Pilot-Automotive-LI-1157RCZ-Wide-Angle/dp/B0026OMV8C[/ame]
Pilot Automotive LI-1157RCZ Wide Angle LED Bulb
The one Amazon review posted says they are red, come in pairs and the load circuit doesn't work on all vehicles. But, if SomeGuy says in his post above he's got 10k Spyder miles without problems, I trust him.
Be really careful with these-- the solder joints break really easy when you're twisting them in.......
Nope. You need LI-1157RCZ bulbs. They run $25-$30 per pair on Amazon. You can Google the p/n, but all the links will eventually take you to Amazon.
FireFly is correct, it is very easy to break the solder on the head if you twist too hard. But if you're careful on the initial install, you won't ever have any problems with them (based on my experience).
I broke that soldered wire but a drop of crazy glue fixed it.
just ordered a set
Hello.. I am a new spyder owner.. had the back rest installed and I am now reading that it is "hell" to change the bulbs with the Sportrack on the spyder.. So I ordered a set of these Bulbs.. I hope they are as good as everyone says.. I have also seen on here where people have shaved a section off their taillight housings that is supposed to make it easyier to change the bulbs.. I wounder if that mode works for those of us who have sport racks..
