Results 1 to 8 of 8
    Mar 2023
    AL
    Default Trunk lock not locking - are they adjustable? Incorrect dealer set-up?
    So we have two 2023 RTL's, on both of them if you lock the trunk you can still open them by pushing on the side (either side) of the latch. I thought I was going crazy but checked another and found it's not the same. Are the locks adjustable? Is it possible the dealer just adjusted them wrong?
    Last edited by Peter Aawen; 10-23-2023 at 08:51 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Vermont
    Quote Originally Posted by SpyderStro View Post
    Look at this video :https://www.youtube.com/watch?v=MVq0_JgBZXU hope this helps.
    Deanna
    Last edited by Peter Aawen; 10-23-2023 at 08:51 PM. Reason: Fixed quote display... ;-)
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Sep 2023
    Harford county Maryland
    Deanna777, thank you for this video. I have/had the same issue on my 2023 Sea to Sky. Fixed
    Mar 2023
    AL
    Awesome! will do in the morning, thank you
    Mar 2023
    AL
    Deanna
    Awesome little video, took less than 10 minutes to do both of them. What an annoying little hiccup while traveling. Thank you soo much.
    Vermont
    Quote Originally Posted by MCole View Post
    MCole, You are Welcome! I am glad that the video helped to fix the issue you had on your 2023 Sea to Sky.
    Deanna
    SpyderStro, I am glad the video helped. You are Welcome!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Oct 2020
    Missouri
    Wife has a 2020 Spyder RTL that had the trunk lid popping open when riding. Could have been the same you tube video for the lock tab adjustment. Luckily has not happened again.
    Vermont
    Quote Originally Posted by ReRose View Post
    ReRose,
    Take a look at the link on post # 2 on this thread.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
Tags for this Thread
