Results 1 to 25 of 25
    May 2019
    USA Idaho
    Default How do you mount your phone to the Spyder?
    I have a 2011 RT Spyder and I am wondering for those who do, where do you mount your phone on the bike? The handlebars on the Spyder are huge and none of the motorcycle mounts I've used in the past to mount phones to the handlebar will fit. Is there some special mount that you guys use for the handlebar or do you use some other methods? Can you buy such mounts on Amazon or eBay?
    Thanks for your insights!
    Active Member jlc41's Avatar
    Jul 2018
    New Jersey
    Hi TouringRider, I got a Tackform mount from Motorcyle Dave, works great. Check it out on youtube.
    Joe
    Lamonster Bright Ryder,
    Lamonster Bright Tail Lighter,
    Lamonster H4 LED Headlights,
    Lamonster LED Fog Lights,
    Lamonster Fog Light Ring Combo,
    Rox Riser
    Lamonster Driver Back Rest,
    Lamonster Frame Mount Drink Holder.
    Lamonster 15" Freedom Shield Wind Shield
    ******* USA flag
    Freecom 2 head sets
    Mirror Wedgies by Squared Away
    Motorcycle Dave's Tachform phone cradle
    Spyderpops Turnsignal LEDs
    Spyder Sisters Shade
    Spyderpops LidLocs
    Spyderpops front fender LEDs by Show Chrome
    Motorcycle Dave's Gel seat insert
    2018 F3L , Blue
    Jun 2018
    Pa.
    I have this: https://www.amazon.com/Techmount-4-T...QQPC2BY1FV42PQ
    It works great for me. Mounts in the center where the handlebars attach and hold the phone tight. I can attach the USB cable easily - I have a 2017 F3 Limited
    Jim
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    I have used Ram Mounts for years on many bikes and with a suction mount in the car/truck. The first thing I made for the 2018 RTL was a mount that goes between the bars just above the switches. I used a few longer bolts and some stainless spacers from Lowes, a bridge cut out of a piece of angle iron I painted black and a Ram Ball. After I made it I found out about Lamonster Garage and saw a mount just like it for sale.
    I also have a Spyder Cuff with Ram balls attached to it. For power I have a 2 USB rocker switch outlet between the bars and a cigarette lighter outlet on the Cuff. I use a Ram Quick Grip to hold the phone. Pics below:
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Mar 2015
    forrest above Reno, Nv
    I use a JT style dash rack I made. A vender here sells one. With a RAM ball , x-grip and medium extension it is up high and I don't have to take my eyes so far off the road.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Recently added this to my 2016 ST-S and am completely satisfied...
    http://www.lamonstergarage.com/can-a...-rs-lamonster/
    Next will be this...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Jan 2015
    southern WI
    Ram mount, and X-Grip on a dash mount
    2016 RTS , Pearl White
    Florida Swamp
    I switch on airplane mode so it can't take any calls or messages and zip it up in a jacket pocket. They can call back when I ain't out riding.
    2019 F3-S , Black & Silver
    May 2019
    USA Idaho
    I use the GPS and other tracking apps when I ride with my other other Bikes, along with Bluetooth and music listening, and I'd like to do the same when riding the Spyder.
    May 2018
    millsboro,delaware
    Has anybody found a way to mount a phone on an RTL that has the factory Garmin Gps in the middle that doesn't involve using the Spydercuff or putting it on top of the dash where my 3 pouches are.
    : 2017 RTL ORBITAL BLUE
    Active Member Ramg66's Avatar
    Mar 2017
    Star, Idaho
    I use the Techmount and love it. Had the X-Grip but like the Techmount better.
    2016 Can Am Spyder RT-S SE6
    I plug it into the socket in the frunk and have absolutely nothing to do with it while riding. I ignore incoming calls on the road and check or make outgoing at stops.
    Blue Springs, Mo
    I have spyder cuff and ram mounts With x grip works well with wifes phone hits my photo button I have 300 photos of white lines. Point being make sure holder mates well with phone. Just saying . Safe travels
    Aug 2013
    SF Bay Area
    Quote Originally Posted by spyder01 View Post
    I use a bracket that attaches to the two bolts on top of the dash. It comes with RAM style ball mounts so you can mount almost anything. I replaced the hard plastic balls with RAM rubber ones and use RAM X-Grip with stem and routed power cord up thru center windshield mount and behind one headlight. I got the cord & USB extension cable from Lamonster. I got the dash bracket from Tric LED.
    2021 F3 Ltd , Magna Red
    I do much the same, but instead of putting my phone in the frunk it's in the phone pocket of my vest or jacket! So it's mounted on the Spyder every time I'm aboard & I never accidentally (or forgetfully) leavit there when I walk away! And on the odd occasion that I'm expecting an important call while I'm out ryding, I bluetooth it to my UClear headset & the speakers on/in my helmet & use voice control to do whatever I might need to do..... and I have a very good call screening service!
    Jul 2018
    Missouri
    This is the setup I use. I had it installed at Pitbull in Bolivar.
    2013 RTS
    BajaRon Swaybar, BRP passenger armrests, JT's GoPro dash mount, Lidlox helmet locks, M2 Shocks, foam grips, Ultimate Seat, Magic Mirrors
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Ryde or talk on the phone. Can't do both. Same with texting, can't ryde and text. I think that was said earlier in the post. Just want to re-iterate. My phone is in the rear luggage box though it is on so my friend can track where I am.
    Feb 2012
    Spring City,Utah
    I have an RTL and I Mount my phone to the handle bars near the switches with 2 hose clamps to hold the 2 ball ram mount to the bars, then a ram x mount to hold the phone.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2015
    Hampton Roads, VA
    Tackform mount from Dave. 100%! I just wrote a review and posted BTW on RT you can get a really nice curved mounting bar (i think from lamonster.com?) for $50 that bolts to the two bolts on the upper dash, to mount RAM ball stuff to. This was one of the first things I got, GPS, phone, dash cam all there. Comes with couple 1" RAM balls that screw in it. Then you get the clamps on Amazon in the length you need (usually 4" works for me).
    Jun 2015
    Hampton Roads, VA
    ANother option is the one from canamspyderaccessories.com that replaces one bolt in the handle bars. I have this on my RT, with the Tackform grip. Just order it without the XGrip. I use this mount also because the wife likes it there. I personally prefer the dash mount so the phone i up high, don't have to look down so far. Depends on your height I guess, I'm 6'5" and she is 5' nothing
    Apr 2012
    Northglenn Colorado
    I have an F3 went, cheap, secure, convenient, simple, fast dismount if rain starts. Don't over think , popsocket
    May 2019
    USA Idaho
    <deleted>
    May 2019
    USA Idaho
    Quote Originally Posted by stevencovert View Post
    Thanks for the info.. Could you provide a link to that curved mounting bar? I tried to look on-line on Lamonstergarage, (only phone) and I am not seeing it there). Also could you provide me a link to your review if possibile of the other mount?
    Thanks.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by TouringRider View Post
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 $35
    2014 RTL Platinum
    Coral Springs, FL
    I have a new 2018 RTL. I installed a techmount made specifically for the spyder https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and this phone holder also made by techmount https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I ran a usb cable from the frunk to the mount (came out the switch cover plate next to the fog light switch. This works great. I use the brp system, but have control of the phone and can get my xm radio, look at my weather radar app and do most everything but still go back to the brp system where I left off. Kind of have the best of both worlds.
