Results 1 to 25 of 30
    Active Member garageguy's Avatar
    Jan 2015
    Flint Hill VA
    Default 12v outlet in frunk has no power
    Took delivery of a new blue 2015 ST-LTD last week. Tried to hook a battery tender with a cigarette lighter connection to the 12v outlet in the frunk and no power. Changed the 5A fuse, tried both F6 (switched) and F7 (unswitched) for the fuse and nothing. Any ideas how to get to the wiring to the outlet or the back of the right hand fuse panel so I can troubleshoot?
    Many Thanks
    Mar 2015
    Brockport, NY
    Default I could be wrong but
    Quote Originally Posted by garageguy View Post
    Many Thanks
    My understanding is that the fuse switching you talked about is for the 12 volt in the rear trunk. I do not know if you can charge through the frunk outlet in front? What many do, myself included, add a pigtail to the battery, which is located just left of that frunk,outlet behind the liner, and then plug your tender to that when needed.
    congrats on the new ride too!
    2014 RT-S Pearl White
    Bryant, Arkansas
    Quote Originally Posted by Brentc View Post
    He has an ST, (no rear trunk)
    Mar 2015
    Brockport, NY
    Default Where are those glasses......
    Dooh
    Bryant, Arkansas
    Dooh
    Jul 2011
    Mitchell, Ontario, Canada
    It may not be hooked up. Dealer does that during assembly. On my 13 the dealer hooked up backwards. Burnt out a couple USB chargers before I caught on.
    The trunk has to come off if that's the problem.
    And for you RT people. The outlet in the front and the back are on the same fuse. So changing the fuse location changes both.
    Bossier LoUiSiAna
    With that said fyi I added my pigtail to the post in frunk lays down out of way of latch & seal just fine fyi the post are 10mm
    ImageUploadedByTapatalk1454888333.316970.jpg as far as no power have you tried anything plugged into it? Charger, light, something simple.. It should have power without switch (ignition, mine does anyway)
    Active Member AZ Y Factor's Avatar
    Jan 2015
    Corona de Tucson, AZ
    I have 2014 STL. Take fuse 6 out and put it in 7, right fuse box which is the one on the left when facing the spyder. I would try another device (iPod or phone) besides the battery tender to see if you have power.
    2014 Spyder ST Limited - Black Currant
    "Yes it's fast and no you can't ride it"
    Mar 2013
    Oz
    My 12v in the frunk 13ST was never connected pre delivery. Frunk had to come off to connect it all up. All good now.
    Jan 2015
    Flint Hill VA
    Yes, have tried a 12V air compressor with a cigarette adapter. Works fine on my RT. dead as a doornail on the ST. The workaround is to attach the BTender harness directly to the battery, but I would like to have a working 12V outlet.
    Removing the entire frunk assembly sounds like a PITA but haven't tried.
    Mar 2013
    Oz
    Don't forget the jumper posts under the black trim which pops off when trunk lid open. We hooked tender cables to these posts, ran cable up to under the centre y piece and fitted 12v outlet next to brake button. Works we'll for tender and I also use it for heated vest. Centre y piece is easy to remove. Had to buy a small 12v outlet as not much depth clearance, still a standard item from auto store.
    Bossier LoUiSiAna
    & only having the bike a week the dealer should be helping you more. Sound like they missed a connection. Check the fuses like others have stated. I've always preferred the pigtail myself. Best of luck to ya
    Bryant, Arkansas
    Well i'll be damned ............. I got a 2015 RTL and there is not one in the front trunk at all, does this mean it still uses the same fuse???
    Cruzr Joe
    Bossier LoUiSiAna
    Cruzr Joe
    Are you sure Joe? You got yours from lamonster at spyderfest didnt ya? (Fyi I was there getting air in background, watching everyone drool over your bike)
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    Like Joe, no outlet in frunk, just one in trunk. 2014 RT
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Jul 2011
    Cruzr Joe
    Yes it does. The wires are there behind the front trunk and connected to the fuse box. You just don't have the optional socket installed.
    Jul 2011
    Quote Originally Posted by loisk View Post
    The OP has a 2015, so no jumper posts to hook up to like on a 2013.
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    You paid how much for your new bike and your fixing it yourself. I think your dealer will be happy to solve problems for you.
    Kenn
    Jul 2011
    Quote Originally Posted by robtdonna View Post
    Your dealer will be happy to sell you one.
    Bryant, Arkansas
    i don't need one in the front trunk, the one in the rear is fine.
    Cruzr Joe
    Jan 2015
    Flint Hill VA
    Quote Originally Posted by kbwitt View Post
    Kenn
    Dealer is too far for this nit. Was hoping for advice on a DIY fix
    Sent from my SM-T807V using Tapatalk
    Active Member ceyer69's Avatar
    Jun 2015
    Wake Forest, NC
    Default Frunk Power/Light
    I just noticed that my 2015 RT S has a light in the front trunk but I don't see it coming on? I assume the lid triggers it?
    2015 SE6 SS
    Elka Stage 2 front and rear shocks
    Lamonster Web Pegs
    General Altimax RT43 Rear Tire
    Lamonster LED Headlights and Fog lights
    Baker Wings
    Bajarons Sway Bar & Links
    Custom Dynamics Fender, Bright Sides and HMT Brake Lt
    Zumo 590
    CB
    Spyder Mudflap
    Lamonster drink holder
    Foam Grips
    Billet Axle Covers
    Stebel Air Horn
    SpyderPops Bumpskid
    SpyderPops belt guard
    SpyderPops Kotte Grills
    TriCLED LED Driving lights
    Magic Mirrors
    Default Frunk Light May Be Switched
    On my '14 RTS the frunk light is on the ignition key switched circuit.
    Greenville Tx
    The 12 v power outlet is swiched. You have to have the key turned on for it to work. This rules out using it foe a battery tender. I don't think battery tenders came with cig lighter plugs anyway. Use the pigtail off the battery.
    2017 F3 Limited
    Active Member Myersd802003's Avatar
    Feb 2016
    Alamogordo, NM
    Try it with the ignition switch on. If that doesn't work, then try running your engine to see if it works. The dealership has many ways of connecting it. I have two on my F3S. One that works when the engine is running and one directly connected to the battery that I will use the cigarette adapter for the battery tender. Your other option is to start taking the spyder apart to figure out if and how they hooked it up.
    2012 RSS (Wife's)
    2015 F3S (Mine)
