Results 1 to 25 of 29
    Sep 2014
    Riverview, FL
    Default Lifting a spyder rt with an atv hydraulic floor jack
    Can someone tell me where to place my ATV floor jack under my 14 Spyder RTL
    May 2014
    Benson, NY
    Default Right here
    Quote Originally Posted by den2614 View Post
    Try this
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Sep 2014
    Riverview, FL
    Thanks Ben, do I glean from your pictures that the jack rolls in/under from the muffler side and at the rear of the muffler?
    May 2010
    Montville & Toms River NJ
    If you have a low jack like the one pictured above you can slide it under any side.If you are working on just the front of the Spyder you can jack up just the front leaving the rear tire on the ground
    Sep 2014
    Riverview, FL
    How far in must the jack go to safely lift the 3 wheels off the ground? Does the spyder wobble when all the wheels are off the ground?
    What is the rated capacity of your ATV jack?
    Mine is only 1,000 pounds, and the newer RTs easily exceed that limit...
    The reason that I ask, is that I've seen lots of ATV lifts with just a half-ton limit.
    But the newer ones also come with 1,500 pound capacities as well...
    Which do you have?
    Default Depends..!
    mostly on what you are going to do. It will lift all wheels but also wobble. Won't fall off if doing normal work. Always good idea to have jack stands for heavier jobs. If cleaning it's good on the lift alone but more than that I set it down on stands. Can't ryde it like a mechanical bull...
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    Great photo
    Is there plenty of frame to use under there if you have the jack a little too fwd or a little bit too rearward ?
    Craig From Albany Oregon
    Best balance is with the outer rail at the end of the frame (further your on the pipe) inner rail towards the front. If too much boolean for you jack stands on front wheels and blocks under rear wheel unless working on belt tire etc the stand under shock...
    Jun 2015
    Midland, TX
    I use an air over hydraulic pitbull jack
    Sep 2009
    Albany, Oregon
    Iguess my question was more ....where do you line the jack up. I think a different post said to line the front "blade" of the jack in line with the operator foot peg mounting point.
    Can you add a "line up" clarification for us ? Thanks !
    Sep 2014
    Riverview, FL
    Bob, .
    My jack is 1500lb rated. When I roll it under from the muffler side it hits the lower fairing/highway peg reducing the amount of the jack that lifts the spyder, causing wobbling. Tomorrow I will try rolling the jack under the opposite side, hopefully having more jack under the frame and less wobble.
    Thanks all for the pictures, they helped a lot.
    Default Will try...
    Quote Originally Posted by WEB-WVR View Post
    view from the left side on an RS. still good idea to check first few times. This may vary on the RT and F3...but this works for the GS/RS/RSS/ST..
    Sep 2009
    Albany, Oregon
    YOU ARE DA' MAN !!! Best photos showing the jack up points and jacking. Thanks....I am sure many will appreciate it !
    May 2015
    Oregon, USA
    Thanks everyone for the pictures, they really help!
    -Fratz
    Aug 2015
    Syracuse, NY
    Quote Originally Posted by fratzba View Post
    -Fratz
    I'd like to get my Spyder off the ground for the winter to avoid flat-spots.
    Would this type of jack beappropriate?
    And if so, is this the right one?
    http://www.craftsman.com/craftsman-m...2&blockType=G2
    Jun 2014
    People's Republic of NY
    Quote Originally Posted by liebowa View Post
    i won't leave on a lift for extended periods.
    use jack stands.
    Sep 2014
    USA
    I make sure the jack is in front of the underside switch or it could bend it.. The pics show good placement but I always make sure its not on the underside switch..
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Nope! that one is 1,000 # rated, use the yellow one show below that on the web page. The yellow one is listed at 1500 #.
    David
    Active Member Rocketman 2012's Avatar
    Oct 2015
    Carthage, Missouri 64836
    Here is what I have: It is a full size Hydraulic lift that will raise to 7 ft at the bottom rail and it lifts enough weight for anything that will fit on it. It was brought in to my "hobby" barn, dropped off the trailer in position and then I drilled the bottom of each post and used "Red Heads," to anchor it. It has made my maintenance and cleaning a breeze as I no longer have to lay down on my side or stay on my knees anymore. These type of lifts only run about $3,500 or so and are worth every penny in my extremely humble opinion.
    Sam
    2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
    Quote Originally Posted by Devious56 View Post
    Where did you come up with the 1000# number? The red one is rated 1500# also. I have one.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Rocketman 2012 View Post
    Sam
    Man I am jelouse. I want one of those for my garage.
    Can you slide the rails in and out for different width vehicles?
    Do you have another portion that fits in it for the rear tire on the Spyder?
    Sent from my SCH-I545 using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Aug 2015
    Syracuse, NY
    Quote Originally Posted by vided View Post
    use jack stands.
    Just curious why this is? Thinking that If I lift it just to get the wheels an inch or so off the ground to keep winter flat spots from appearing - am I putting something at risk?
    Pump the tires up a little extra and flat spots won't happen. You're overthinking the issue, IMO.
    Jun 2014
    Overtime the pressure in the lift can leak and the lift lowers.
    also someone may bump the bike and knock it off the lift.
    Quote Originally Posted by WasWinger View Post
