Results 1 to 12 of 12
    Active Member Tec35's Avatar
    Dec 2019
    Rhode Island
    Default Changing Headlights to LED - nose piece removal
    Hi
    I am a new 2019 F3 (base model)spyder owner, this is my first Spyder(bought couple months ago). I am loving the new ride. I installed some aftermarket fog lights today and I was going to switch out the headlights to led. I am having an issue removing the nose piece above the frunk. Per Slingmods video, I just need to remove the bolt and lift up on it and it should come off. I tried to pull the nose piece off but it would not come off. I did not force it as I do not want to break it. Should it just come off or should I remove more panels before removing the nose?20200112_195330.jpg
    2017 F3 limited , Black
    Jan 2019
    Kentucky
    I access the headlight from the top. I remove the instrument cluster and the panel under. The nose is attached in the front of this panel.
    Dec 2019
    Rhode Island
    Thank you! I will take a look at it and try to install that way.
    Active Member timd35's Avatar
    Aug 2019
    Texas
    There is a Torx bolt/nut holding the front nose peice on. I ran into the same thing. You have to gain access to the following screw in the picture. I do not think the 2018 had this and so the Slingmods video just showed it popping off.
    Dec 2019
    Rhode Island
    Quote Originally Posted by timd35 View Post
    There is a Torx screw holding the front nose peice on. I ran into the same thing. You have to gain access to the following screw in the picture. I do not think the 2018 had this and so the Slingmods video just showed it popping off.
    Thank you, that explains it! Now i know how to attack it.
    Nov 2018
    Lisbon, Portugal
    I've made a tutorial on how to activating the lowbeams for the F3 (Non US and CA models).
    Not what you are looking for, but the whole dismantling process to access the headlights is documented there:
    https://www.spyderlovers.com/forums/...and-CA-models)
    2018 F3S , Monolith Black Satin
    Aug 2019
    Stoughton, WI
    In my experience with a couple add-ons, Slingmods skips/neglects to tell some steps. As far as the LED headlight bulb install, they neglect to tell you that the nose piece is held on by a nut/bolt. I inquired with them about this and they advised the install was straight forward as shown
    2022 RT Sea To Sky
    Dec 2019
    Rhode Island
    Quote Originally Posted by MakoShark2 View Post
    Thank you, I will definitely use them to assist in the process.
    Dec 2019
    Rhode Island
    I agree with you troop. I just installed the ARC fog lights and had to make some minor modifications, could not fit a washers for the bolts in some areas and the switch was to big for dash. Per their instructions everything should fit 2019 F3.
    I noticed you have factory heated grips, did you install them yourself? If so was it a straight forward install? I got a set for a Christmas gift and that is my next project after the headlight install.
    Aug 2019
    Stoughton, WI
    I negotiated the heated grips/install labor in my purchase. Sorry that I can't help you with that.
    2022 RT Sea To Sky
    Dec 2019
    Rhode Island
    Worth a shot!..lol Thank you for your help!
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Quote Originally Posted by Tec35 View Post
    Not sure if this help
    https://youtu.be/jkqjMu6qpQI
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
