Results 1 to 14 of 14
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Any way to get rid of the Read the card message?
    Is there any way to not have this message to be displayed every time you start up ??
    2016 Limited Special Edition
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Dec 2018
    Long Island
    I've been seeing that message since July of 2012, so I would say ignore it as I do.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
    Quote Originally Posted by LongIsland View Post
    ..... It's there because the LAWYERS told BRP to add it - - - a CYA .... It's similar to the music you hear while waiting after being put on hold. It lets you know the system is still working.... After I had my DESS turned off, I found that I could just hit the start button with no waiting and the RT would Start..... Mike
    I read it the first time, about June 2008. Have not paid attention since.
    Ignore it, but it will not go away. BRP has to do a little bit of CYA.
    Northern Kalifornia
    Add stage 1 or 2, maybe?
    Houston
    Quote Originally Posted by johnv50 View Post
    thanks johnv
    You cannot get rid of it but you also do not have to wait for it. Just press MODE and then start, no need to wait on your 2016.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Harrington, Australia
    Yep…..that’s exactly what I did on my ‘16F3 and now do on my ‘21 RT, JC …..no delay necessary.
    HeliBars Handlebars
    Kenda Kanine rear.
    Florida Swamp
    Easy to get rid of it....... punch the MODE button when you see it.
    2019 F3-S , Black & Silver
    Quote Originally Posted by Gwolf View Post
    ... Or, Spay paint the display! (No need to thank me. My genius advise is always free!)
    Nov 2022
    Iowa
    Default Mode button to start
    thanks johnv
    Punching the mode button is part of the safety start procedure, right? So the blurb is just reminding you to do that. On the Ryker, you have to reverse twist the throttle to complete the start procedure.
    Northern Kalifornia
    I remember when Ruger first imprinted safety instructions on their single 6's. What a disgrace it was to a great sidearm. I have the same feeling about my spyder and I haven't read the prestart on my RT for so long that I don't remember what it even says. Now I just hit start, try to miss the clunk, and then take off.
    Feb 2020
    illinois
    As some have stated above, turn key on, push mode button, then push start button. Works this way on 2020 RTL and now on my 2022 F2L Limited.
    NorCal - Northbay
    Well, when I move to Stage 2 from 1 they couldn't remove the text, only bypass the need to hit the mode button to start, but you still have to hit the mode button to make the damn text go away at some point! Otherwise I'm rydin down the road with it scrolling away.... :-(
    Chuck
    Linden, CA
    thanks johnv
    It's like HERPES it NEVER goes away
