Results 1 to 7 of 7
    Active Member mhan's Avatar
    Mar 2021
    Prescott AZ
    Default Made rear trunk organizer for 2021 RTL S2S
    Made this handy rear trunk organizer for my 2021 RTL S2S for $10.00.
    Garden tool belt from Amazon.
    https://www.amazon.com/dp/B08QG7HPX8...roduct_details
    and a couple snaps. No more taking everything out of the trunk to find the thing I know is in there.
    2021 RTL S2S, BRP arm rests, smart mount backrest, Pedal Commander, F3 position B handlebars, adj side vents.
    2021 Sea To Sky , Green
    Oct 2021
    Wichita, KS
    How did you install the snaps for the Spyder?
    Peter Pan has struck again!
    Mar 2021
    Prescott AZ
    The snap base uses a small screw to secure it to the surface. Drilled small hole thru hinge cavity on each side.
    Oct 2021
    Wichita, KS
    Quote Originally Posted by mhan View Post
    Thanks for the reply. Do the snaps have to be installed into the canvas bag or does the lip hold it in? I was thinking I would need some special grommet tool or something.
    Mar 2021
    Prescott AZ
    The top snap is in 2 pieces installed thru the material and crimped over by means of shaped anvil and punch. Was snap kit I purchased at Walmart or a hardware store, I don't remember.
    Like this one at Amazon.
    https://www.amazon.com/30sets-Canvas...%2C146&sr=8-62
    Oct 2021
    Wichita, KS
    I just purchased the belt and snap kit from Amazon through your links. Thank you very much sir!
    Durham,Maine
    Neat idea!!!! Good job!!!!
    2012 RTL , Pearl
