Results 1 to 17 of 17
    Very Active Member smokster's Avatar
    Sep 2007
    Default Gas can in trunk
    Anyone find or try to fit a gas container in the front trunk.
    I know its not the safest, but will want to do some rides wout gas stations.
    Plan on doing some long mountain trips and want to make sure I don't run out.
    Durham,Maine
    They make stackable gas cans for snowmobiles or atvs, that have a mounting post to hook them down. If you had a RT with a back rack I think I would come up with a way to install it there. Another opt is, do you have a reserver hitch? You could make a small rack that slides into the hitch that you could carry gas on that. I don't know if I would carry in the front trunk, there is a weight limit up there, not to mention it's going to get warm in there! Good Luck, be safe!!
    2012 RTL , Pearl
    Default Depends...
    I do carry a liter metal fuel bottle for emergency but I am thinking you are looking for more capacity. There are many that carry them in the side bag and one even installed an additional tank in the frunk. So it would be how much you want to carry and the mileage you get per gallon. But to do it .... many do and types of gas containers are many that would fit just right....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    If you use your trunk for gas you’ll never want to use it for anything else, unless you don’t care if your stuff smells like gas. If you do your research ahead of your trip you can plan for gas stops. Otherwise get what Chupaca has, they don’t smell.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2017
    Mesa, Arid-Zone-A
    I would be leery of carrying gas in either the trunk or frunk. They both have electrical things installed and are not vapor proofed. One little spark and you become a Roman Candle. Carrying gas in a side bag would be a much better option. I have also seen gas containers attached to the passenger foot boards but then you can't have a passenger...... Jim
    Semper Fi
    Faribault, MN
    I carry a made for motorcycles 1 Gal REDA Innovations Fuel Can RGC1001 Has an excellent spout system that prevents leaks while stored in bike, but easily provides you with a one gallon reserve. Its rode in my Frunk and Trunk.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Greenville Tx
    Start a log to keep track of your fill ups. You will discover that you are not utilizing your whole tank capacity. An F3 has a 7.1 gallon capacity. most fill ups when I get a low fuel light are around 5 gallons, maybe a little more. My range is usually around 250 miles on the highway. Its hard to go that far on a spyder without stopping for a rest.
    2017 F3 Limited
    Default Extra gas
    The " it will smell thing " is a myth..... It depends on what type of container you store the Gas in ….. I have a 750ml Tequila bottle ( glass ) in the rear trunk, it's sort of Rectangular shaped so it fits nicely attached ( by a HM bracket to the right side ) It has NEVER smelled or leaked …. The Cap was made to seal Alcohol in the bottle. That's a lot thinner to say water and about the same as gasoline...…. I am going to replace that container with a like shaped " Burnett's Gin " … PLASTIC bottle , because it would be a bit safer …… Carrying any Flammable liquid is a crap shoot ….. But to put it in prospective ….. You are carrying GAS in your gas Tank ….and a lot more of it …… just sayin ….. Mike
    Sep 2009
    La Valle, WI
    Do not put gas on a hitch rack. Those racks bounce with the suspension. The gas cans would probably burst open.
    2018 F3 Limited , Oxford Blue
    Northern Kalifornia
    Where in the USA are you going to ride that is further than 250 miles between fuel stops?
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Mike...I hope you aren't mixing Tequila and Gin...
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Quote Originally Posted by Raprider View Post
    ...…NEVER …….. Mike
    Bossier LoUiSiAna
    What I'm attempting,https://www.spyderlovers.com/forums/...02841-Tourtank
    still ongoing
    Florida Swamp
    MSR Fuel Bottles........ they are metal, made to carry fuel, and they don't leak....... up to 30 oz size.
    2019 F3-S , Black & Silver
    Active Member ChicagoSpyder's Avatar
    Chicago
    Quote Originally Posted by smokster View Post
    Rotopax makes some very nice cans that will fit, there are also some Rotopax knockoffs if you want to save some money, although they are not as robust as a Rotopax.
    https://rotopax.com/
    Quote Originally Posted by canamjhb View Post
    There is always a concern when hauling fuel, but I have at least 40,000 miles carrying fuel under the hood of a snowmobile using a Tour Buddy which siphoned the fuel off the Tour Buddy via the gas tank vent hose, it was simple and effective. A Spyder will never see the abusive conditions a sled goes through on a typical ride.
    With rider forward sleds there is no longer the space haul fuel under the hood so now we use Rotopax stored in saddlebags, not as convenient as the Tour Buddy but it beats a cold lonely walk out of the bush.
    2018 F3 Limited , Black/Chrome
    Mar 2017
    >CLICK ME<
    Safe fuel bottles have come down in price considerably from when I was able to out-ride my gas tank. >sigh< Those days are gone.
    Side note: I found aluminum 20 oz water bottles for $1 at a hardware store. The only thing I had to replace was the o-ring to a petrol safe one at about 15¢ each. Served me well on my quads and GL1800 wing.
    Dec 2015
    Oakley Utah
    Find another solution. This one is fraught with problems.
    2014 RTL Platinum
