Results 1 to 14 of 14
Thread: Possible fuse?
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Possible fuse?
    Anyone have this issue? Went to pull the bike in the garage 2013 RT Sm5.... went through the normal routine for start up… Lights came on, radio came on, hit the mode button, hit the starter, and the pipe went dead… I'm guessing maybe a fuse… But it's late and it's dark and I can't check fuses until tomorrow but it's really weird.
    Mar 2017
    Salisbury,NC
    how old is battery? battery connections?
    Jan 2018
    North Carolina
    brand new battery....will check connections and fuses in the daylight
    Apr 2017
    North Central Florida
    Quote Originally Posted by Tatonka View Post
    What went dead ??
    If ALL of the power disappeared, then battery or main battery connection is a more likely cause.
    EDIT: And just because the battery is new doesn't necessarily mean that it can't go bad.
    Jan 2018
    North Carolina
    What went dead ??
    Exact, loose neg. battery cable
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Don't forget to check the relays. I had similar issue on my 2013 RT-S turned out to be loose relay. To prevent relay coming loose I placed piece of stiff foam on the relay thick enough so it would apply pressure when covered.
    Ride safe!
    2022 Sea-T0-Sky
    Jan 2018
    North Carolina
    What relay are you referring to?
    Apr 2017
    Second request:
    Exactly WHAT went dead ?
    Everything ??
    Jan 2018
    North Carolina
    Yes, everything went out....key on...it cycled
    thru...hit mode button...hit started button and all
    Went dead...that’s why I feared the worst...
    Apr 2017
    SO......back to the original suggestion that you have a bad battery OR a bad connection to the battery.
    You need a voltmeter to tell where the problem is.
    Probably the most common culprit when this happens (right after a bad battery) is the OTHER end of the negative cable that goes to the frame being loose or corroded.
    Jan 2018
    North Carolina
    well, in this case it just took couple of turns with a screw driver on the neg cable connection.
    Apr 2017
    Good.
    The only remaining question is: Who installed your new battery ?
    Often you can't get the bolts tight enough with a screw driver.
    And adding a "star washer" is good to keep them tight.
    Jan 2018
    North Carolina
    Yes....I did it...I confess.....
    Jul 2010
    Las Vegas, NV
    Glad it’s fixed!
    Joe Meyer
